One question,
What DC-DC converter is gonna be used, ive noticed that GND pin is on the bottom instread of middle? :oops:
The TF360 rev2 arrives
8 Bit Dreams
- Moderator Team
Re: The TF360 rev2 arrives
Higgy
How tolerant are the sockets with desoldered 060's?
I have one desoldered from industrial hardware. There are no solder blobs and i have been over where possible with braid.
alenppc
- Moderator Team
From what I can see, it's the dual solution, same as the 1260, so you can use any pinout.8 Bit Dreams wrote: 03 Apr 2020 19:03 One question,
supaduper
Hi Viktor me Steve and Chucky use these DC convertors . they work great and run rather cool, unlike the Linear ones, they are sold in kit form by Tbtorro on Amibay , link below, I know Alen has used cheaper off the shelf ones from Digikey so ask him for a link8 Bit Dreams wrote: 03 Apr 2020 19:03 One question,
http://www.amibay.com/showthread.php?10 ... B1260-etc)
It should be fine fellaHiggy wrote: 03 Apr 2020 19:13 How tolerant are the sockets with desoldered 060's?
alenppc
- Moderator Team
Yes, I am using DigiKey part 1589-1464-ND, fantastic device, fits neatly underneath the board and does not heat at all.
8 Bit Dreams
- Moderator Team
Ok, thanks Alen!
Will grab one with my next order
- Admin sponsor
https://www.exxosforum.co.uk/forum/viewt ... 120#p260518 Bit Dreams wrote: 03 Apr 2020 19:03 One question,
quantum8
It's a thing of beauty!
Now the hard decisions: whether to get this one or the 1200 variant when they become available.
Higgy
Huston we have lift off :)
Do we need a Beta Tester thread or write in here?
Ghetto tip - if your swaping 060s out for testing, cut 3 strips of ~3mm wide card and place between cpu pins at top, middle and bottom positions. This holds the CPU off the socket a bit to make it easier to remove if you don't have correct removal tool.
Note: I don't think the cpu gets hot enough to burn card. But terrible fire warning ;) Fahrenheit 451?!?
Higgy
I fitted a fan that i had about.
It is quite surprising that although there looks to be loads of space inside the CD32 there never seems to be enough!
I could not fit a heatsink and a fan on top with what I had around. If the fan is directly glued to the CPU then there is no way for the air to get out, so I raised it up on some rubber feet and glued it on. Probably ok for home, but probably would not survive a trip in the postal service!
Next job is to put the CF in my PC and transfer on some specific 060 demos etc.
I know there is RTC clock talk, I wonder about using a flexi cable and then flip the RTC over into the dead space of the CD32 instead of over the CPU. Just an idea.
