I dont think its vital. But we'd need 2 ports at least otherwise.arkadiusz.makarenko wrote: 02 Mar 2020 21:47 @terriblefire
Do we really want hub support for this project?
TF Riser Revision 0 Arrives
- Admin sponsor
Re: TF Riser Revision 0 Arrives
arkadiusz.makarenko
- Moderator Team
This bit should be easily done on any newer stm32 chip.terriblefire wrote: 03 Mar 2020 00:03I dont think its vital. But we'd need 2 ports at least otherwise.arkadiusz.makarenko wrote: 02 Mar 2020 21:47 @terriblefire
~ Stanislaw Lem
~ Stanislaw Lem
arkadiusz.makarenko
- Moderator Team
I managed to complete composite device support, and bugfix some issues related to initialisation of gamepads and overflow of device data buffer.
Everything seems to work fairly stable on almost all of my device. Occasional issue may be related to power issue as it happens only when one very cheap device is connected. I slapped few additional caps here and there, and it seems to be a little bit better (it all may be pure coincidence).
Over the weekend I am planning to put everything together and try to test it on CD32.
~ Stanislaw Lem
~ Stanislaw Lem
arkadiusz.makarenko
- Moderator Team
I didn't have much success with board on CD32. I did start Diagrom.
With USB mouse I have what it seems random moves and clicks, and even graphical glitches and disappearing screen output.
On keybaord it is much more stable (far from perfect), but keyboard input is not always registered.
~ Stanislaw Lem
~ Stanislaw Lem
- Admin sponsor
I’m just back from AZ. Which chip did you use and I’ll order one to swap out
arkadiusz.makarenko
- Moderator Team
f730, but I can port it to f105 easily just by copying one folder - STM32_USB_Host_Library.terriblefire wrote: 08 Mar 2020 09:51 I’m just back from AZ. Which chip did you use and I’ll order one to swap out
f730 - STM32F730R8T6 MCU, 32BIT, 216MHZ, LQFP-64 farnell
RS didn't have this chip in stock.
But this would be only necessary for 2 USB ports support.
~ Stanislaw Lem
~ Stanislaw Lem
- Admin sponsor
Ok if you can port to the 105 and share the sources i'll try it out early this week.
arkadiusz.makarenko
- Moderator Team
I pushed library changes. I hope it will just work.terriblefire wrote: 08 Mar 2020 12:23 Ok if you can port to the 105 and share the sources i'll try it out early this week.
~ Stanislaw Lem
~ Stanislaw Lem
- Admin sponsor
will take a look tomorrow. I'm doing my jetlag reentryarkadiusz.makarenko wrote: 08 Mar 2020 15:27I pushed library changes. I hope it will just work.terriblefire wrote: 08 Mar 2020 12:23 Ok if you can port to the 105 and share the sources i'll try it out early this week.
arkadiusz.makarenko
- Moderator Team
I think I have bug somewhere, as now on f105 (on HID2AMI with my usb library) I get HardFault crash during mouse initialization. It was working fine before :D. Need to understand how to troubleshoot hardfaults a little bit better to find this one.
~ Stanislaw Lem
~ Stanislaw Lem
Users browsing this forum: apple [bot], ClaudeBot and 2 guests
