TF Riser Revision 0 Arrives
TF CD32 Riser
Re: TF Riser Revision 0 Arrives
arkadiusz.makarenko wrote: 02 Mar 2020 21:47 @terriblefire
Do we really want hub support for this project?
I dont think its vital. But we'd need 2 ports at least otherwise.
arkadiusz.makarenko
Moderator Team
Moderator Team
Post by arkadiusz.makarenko »
terriblefire wrote: 03 Mar 2020 00:03
This bit should be easily done on any newer stm32 chip.
~ Stanislaw Lem
arkadiusz.makarenko
Moderator Team
Moderator Team
I managed to complete composite device support, and bugfix some issues related to initialisation of gamepads and overflow of device data buffer.
Everything seems to work fairly stable on almost all of my device. Occasional issue may be related to power issue as it happens only when one very cheap device is connected. I slapped few additional caps here and there, and it seems to be a little bit better (it all may be pure coincidence).
Over the weekend I am planning to put everything together and try to test it on CD32.
~ Stanislaw Lem
arkadiusz.makarenko
Moderator Team
Moderator Team
I didn't have much success with board on CD32. I did start Diagrom.
With USB mouse I have what it seems random moves and clicks, and even graphical glitches and disappearing screen output.
On keybaord it is much more stable (far from perfect), but keyboard input is not always registered.
~ Stanislaw Lem
I’m just back from AZ. Which chip did you use and I’ll order one to swap out
arkadiusz.makarenko
Moderator Team
Moderator Team
terriblefire wrote: 08 Mar 2020 09:51 I’m just back from AZ. Which chip did you use and I’ll order one to swap out
f730, but I can port it to f105 easily just by copying one folder - STM32_USB_Host_Library.
f730 - STM32F730R8T6 MCU, 32BIT, 216MHZ, LQFP-64 farnell
RS didn't have this chip in stock.
But this would be only necessary for 2 USB ports support.
~ Stanislaw Lem
Ok if you can port to the 105 and share the sources i'll try it out early this week.
arkadiusz.makarenko
Moderator Team
Moderator Team
terriblefire wrote: 08 Mar 2020 12:23 Ok if you can port to the 105 and share the sources i'll try it out early this week.
I pushed library changes. I hope it will just work.
~ Stanislaw Lem
arkadiusz.makarenko wrote: 08 Mar 2020 15:27
will take a look tomorrow. I'm doing my jetlag reentry
arkadiusz.makarenko
Moderator Team
Moderator Team
terriblefire wrote: 08 Mar 2020 20:11
I think I have bug somewhere, as now on f105 (on HID2AMI with my usb library) I get HardFault crash during mouse initialization. It was working fine before :D. Need to understand how to troubleshoot hardfaults a little bit better to find this one.
~ Stanislaw Lem
Return to “TF CD32 Riser”
Users browsing this forum: ClaudeBot and 12 guests
