Good stuff. Looking forward to this.
TF330 WiFi?
MickGyver
Re: TF330 WiFi?
Did anybody here managed to get WIFI working, and could give some hints on how to set things up?
- Admin sponsor
Re: TF330 WiFi?
There are many ways to do this.
But all the TF330 does is let you talk to the ESP module. You need to choose a TCP/IP stack for the Amiga and then create a dial script for the ESP module.
MickGyver
Re: TF330 WiFi?
Thanks, so in practice, I guess there isn't any "easy" solution to connect to a wifi network using the ESP module? It's hard to try anything with no documentation at all.terriblefire wrote: 17 Sep 2019 13:32 There are many ways to do this.
Did somebody else here get this working and could share some insight?
- Admin sponsor
Re: TF330 WiFi?
I got it working using a zmodem esp firmware, roadshow and pppd on a Linux box to route it.
The CF card, ESP module and pi have all gone awol
Glen M
Re: TF330 WiFi?
Sorry to dig out an older thread but I'm I reading this correct that you can add a ESP8266 module to the TF330 as a networking solution?
I can't find much info on this but it sounds interesting. Has a guide ever been pulled together for this?
- Admin sponsor
Re: TF330 WiFi?
There isn’t really a guide.
Essentially the ESP module appears on the Amiga serial port...
How you make it work is kinda a software thing from there.
- Admin sponsor
Re: TF330 WiFi?
I've had a go at this this afternoon. I got stuck when i tried to make roadshow use SLIP. Doesnt seem to be obvious how to do this.
sugar
Re: TF330 WiFi?
This post may be low on information but you should configure an interface at devs/netinterfaces to use device=slip.device and then start that interface.
- Admin sponsor
Re: TF330 WiFi?
Yeah i tried and got an error. Also roadshow doesnt come with slip.device. I had to hunt for it on aminet.sugar wrote: 23 Feb 2020 21:46 This post may be low on information but you should configure an interface at devs/netinterfaces to use device=slip.device and then start that interface.
This maybe an alternative approach for people to get going
https://blog.nootch.net/post/amiga-bbs-online-2019/
