Subzero79's build
TF530 - 63030 + RAM Board
Re: Subzero79's build
Sounds like bad / loose connections on the relocator.
Subzero79
Post by Subzero79 »
All pins soldered
If i use ide boots with 0 mb fast
If no ide atached and boot from floppy 2 mb memory
8 Bit Dreams
Moderator Team
Moderator Team
Post by 8 Bit Dreams »
Check ide cable length, should be approx 10cm
this usually happens when ide cable is too long
Subzero79
Post by Subzero79 »
Ok cut ide cable to 2cm and is beter
Sometimes lose fast ram. Un 5;to 6 times is ok
8 Bit Dreams
Moderator Team
Moderator Team
at the moment You don't have FastRAM - Your speed is also like stock 7Mhz CPU,
it's because IDE isn't buffered, try to avoid long ide cables
8 Bit Dreams wrote: Mon Feb 17, 2020 7:14 pm at the moment You don't have FastRAM - Your speed is also like stock 7Mhz CPU,
Or buy an IDE buffer. Possibly i should make a cheap buffer design available so people can use one if they need.
Return to “TF530”
