Subzero79's build
TF530 - 63030 + RAM Board
Re: Subzero79's build
It’s not the socket. You wouldn’t get DiagROM or the red ESM screen if the CPU wasn’t working fine.
Subzero79
Post by Subzero79 »
FIXED removed all memory ic used fresh solder and reflow with hot air.now it boots without the dianostic screen
diagrom swows me 2 mb thanks tf
Subzero79
Post by Subzero79 »
Works
Subzero79
Post by Subzero79 »
Rollin fast
Nice work.
Subzero79
Post by Subzero79 »
i have installed classic wb and mmu libraries and now i take 10.13 mips 1.36 mflops alittle better mmu active -eats 512k ram but is ok for everyday usage
Subzero79
Post by Subzero79 »
i found when used ide cable longer than 2 inch ide lost reiability and most probably duy to crosstalking i lost 2 mb memory at bootup,when i use
2 ingh long cable or aluminium foil on longer ide cable all works fine
strange
Subzero79 wrote: 03 Jan 2020 16:49 i found when used ide cable longer than 2 inch ide lost reiability and most probably duy to crosstalking i lost 2 mb memory at bootup,when i use
strange
its because of the 2 layer board on the TF530. The TF534 behaves much better because its 4 layer.
Subzero79
Post by Subzero79 »
[attachment=0]IMG_20200207_130054.jpg[/attachment
Finally found firmware and no 0mb ram anymorebafter reboot.boobipnmemory expansion worksnok 2 chip ram 1 slow ram
Subzero79
Post by Subzero79 »
@tf with ide attaced i loose fast memory with rellocator
Psu 5 volt is 4.6 on accelerator
Without rellocator all work ok
Without ide with booting from gloppy fast memory is on 3.14
Kickstart used
Return to “TF530”
