Subzero79's build
- Admin sponsor
Re: Subzero79's build
It’s not the socket. You wouldn’t get DiagROM or the red ESM screen if the CPU wasn’t working fine.
Subzero79
FIXED removed all memory ic used fresh solder and reflow with hot air.now it boots without the dianostic screen
diagrom swows me 2 mb thanks tf
Subzero79
Works
Subzero79
Rollin fast
- Admin sponsor
Nice work.
Subzero79
i have installed classic wb and mmu libraries and now i take 10.13 mips 1.36 mflops alittle better mmu active -eats 512k ram but is ok for everyday usage
Subzero79
i found when used ide cable longer than 2 inch ide lost reiability and most probably duy to crosstalking i lost 2 mb memory at bootup,when i use
2 ingh long cable or aluminium foil on longer ide cable all works fine
strange
strange
- Admin sponsor
its because of the 2 layer board on the TF530. The TF534 behaves much better because its 4 layer.Subzero79 wrote: 03 Jan 2020 16:49 i found when used ide cable longer than 2 inch ide lost reiability and most probably duy to crosstalking i lost 2 mb memory at bootup,when i use
strange
Subzero79
[attachment=0]IMG_20200207_130054.jpg[/attachment
Finally found firmware and no 0mb ram anymorebafter reboot.boobipnmemory expansion worksnok 2 chip ram 1 slow ram
Subzero79
@tf with ide attaced i loose fast memory with rellocator
Psu 5 volt is 4.6 on accelerator
Without rellocator all work ok
Without ide with booting from gloppy fast memory is on 3.14
Kickstart used
Kickstart used
