I'm configuring ClassicWB3.9 for the TF330, but I have two problems.
1st I can't remove the DF0 icon
2nd I cannot insert the CD to play automatically and the icon appears on the desktop.
Note: forgive me my English (translate):help
Help to configure ClassicWB3.9 with TF330
- Admin sponsor
Re: Help to configure ClassicWB3.9 with TF330
Im by no means an expert here... but
1. to remove DF0:
go to Devs:DosDrivers and remove DF0 & DF0.INFO
2. to setup CD0;
move or copy CD0 & CD0.INFO from Sys:Storage/Devs/CD0 to Devs:DosDrivers
Maybe others will know more
1. to remove DF0:
2. to setup CD0;
hardgb
I'm not finding DF0.
matt020
Check startup sequence for "addbuffers df0:"
if it is there, add a semicolon to stop it from loading.
;addbuffers df0:
and tell me if that works?
;addbuffers df0:
hardgb
I didn't find any reference to DF0 in the startup-sequence. I believe the closest thing to it was this
supaduper
What do you mean by configuring the CD to play automatically ?, do you mean a CD32 game Cd to play on Boot up, if yes then it will not work as there is a bug on the TF330 the moment which means most CD32 games will not boot automatically ..or do you mean something else ?
I am also puzzled by the DFO error as for it to appear it would have to be in the Startup Seq as mentioned for it to show up on the Workbench
I have a similar CWB OS 3_9 image to you so I will try it out and see if I get the same errors
Also your images are not showing up in your post :)
- Admin sponsor
Wasnt aware of this?supaduper wrote: 18 Jan 2020 06:13 What do you mean by configuring the CD to play automatically ?, do you mean a CD32 game Cd to play on Boot up,
supaduper
It`s just the `Disable` bug Steve that I am telling him about, where the removing of the Jumper does not disable the TF330 from the CD32 meaning some CD will boot some others not
- Admin sponsor
Ah I read it as the CD32 would not boot a game from CD with a TF330 in. No worries.supaduper wrote: 18 Jan 2020 09:44 It`s just the `Disable` bug Steve that I am telling him about, where the removing of the Jumper does not disable the TF330 from the CD32 meaning some CD will boot some others not
supaduper
To stop the DF0 unreadable icon appearing on WorkBench edit your Startup-Sequence as I have done by adding this line before the first Setpach command
SetPatch NOROMUPDATE QUIET
