Network Tools needed (Remote Amiga Login)
Ok so in what follows I am aware of the security implications. Don't need to tell me about them. Thats generally been my day job for the last 10 years.
I want to accomplish the following.
I would like to to be able to sit at a PC and pull code from Git and build it on my Amiga.
I would like to be able to telnet to my Amiga and get a CLI.
My Amiga is running an 060 and has an ethernet card thats running Roadshow.
Essentially i want to run a telnetd and bind it to my ethernet card.. and use git if possible.
Re: Network Tools needed
Looks like there is a git implementation for Amiga
https://github.com/sba1/simplegit
EDIT: ah apparently OS4.. so not really for Amiga.
dalek
Post by dalek »
One suggestion (since I think you'll never get a practical implementation of git on AmigaOS classic - crypto and filesystem limitations) would be to use CVS on the Amiga side and a git-cvs server on a linux machine.
Other workarounds would be to nfs or samba mount the code from a linux machine, and commit on linux.
As for telnetd, a bit of googling shows telnetd server for MiamiDX - I have no idea about roadshow.
Sounds like a pretty out there plan you have going :)
I just want to write code on visual studio code and deploy and run it on a real amiga via a script.
Build, Deploy, Test.... really simple with anything except an Amiga.
WinUAE doesnt cut it when hardware dev is involved too.
dalek
Post by dalek »
So cross-compiling locally and then just sending the binary over the network isn't what you're after?
dalek wrote: Sat Dec 07, 2019 11:47 pm So cross-compiling locally and then just sending the binary over the network isn't what you're after?
how do i run the code and see the output without a cli? No i need the remote CLI.
Well i dont understand why its so hard. I just wanna start newshell on a telnetd and git pull my code. Its exceptionally basic computing.
dalek
Post by dalek »
CLI part should be easy enough with telnetd from aminet as a "server" in roadshow - I downloaded the demo version and the config seems straightforward - assuming the same for ftpd.
From there it's just a matter of git post-commit hooks to trigger an expect script that "logs in" to the amiga to do whatever you can imagine.
OK this is the bit i dont get with roadshow. It doesnt create a AmiTCP: assign so i have no idea where to add the inetd lines and i cant find any mention of it easily in the docs.
dalek
Post by dalek »
Aaargh I see what you mean! I gave up with (the demo version of) roadshow. I got this far:
In DEVS:Internet/servers:
telnet stream DH0:serv/telnetd
In DEVS:Internet/users:
NAME=root UID=0 GID=0 PASSWORD=root DIR="S:" SHELL="*newshell * from s:remote-startup"
Took me a while to work out things aren't configured in AmiTCP:db/passwd after all, and that the password in "users" is in plain text.
But it just hangs after successful login (SHIFT+ALT+F8 brings up the network log).
Maybe it works in the registered version? Failing that back to amitcp...
EDIT: this is with telnetd2.0
dalek
Post by dalek »
Actually just tried ttyhandler and it works with the roadshow demo.
Same DEVS:internet/users file.
In DEVS:internet/users:
NAME=root UID=1 GID=1 PASSWORD=root
In DEVS:internet/servers:
telnet stream AmiTCP:serv/ttyhandler
Login: root
Password:
          TTY0
              New Shell process 7
Directory: "Workbench:"   Read/Write
C                      | Classes                | Devs                   |
Expansion              | Fonts                  | L                      |
Libs                   | Locale                 | MUI                    |
Prefs                  | Rexxc                  | S                      |
Storage                | System                 | Tools                  |
Trashcan               | Utilities              | WBStartup              |
.backdrop           14 | Devs.info          628 | Disk.info          652 |
Expansion.info     632 | MUI.info          1233 | Prefs.info         724 |
Storage.info       628 | System.info        628 | Tools.info         628 |
Trashcan.info     1172 | Utilities.info     628 | WBStartup.info     628 |
Files:              12   Dirs:               18   Size:             8195
Disk Size:    52427776   Disk Used:    17451520   Disk Free:    34976256
7>
Haven't tried compiling anything though.
