Network Tools needed (Remote Amiga Login)
- Admin sponsor
Ok so in what follows I am aware of the security implications. Don't need to tell me about them. Thats generally been my day job for the last 10 years.
I want to accomplish the following.
I would like to to be able to sit at a PC and pull code from Git and build it on my Amiga.
I would like to be able to telnet to my Amiga and get a CLI.
My Amiga is running an 060 and has an ethernet card thats running Roadshow.
Essentially i want to run a telnetd and bind it to my ethernet card.. and use git if possible.
- Admin sponsor
Re: Network Tools needed
Looks like there is a git implementation for Amiga
https://github.com/sba1/simplegit
EDIT: ah apparently OS4.. so not really for Amiga.
One suggestion (since I think you'll never get a practical implementation of git on AmigaOS classic - crypto and filesystem limitations) would be to use CVS on the Amiga side and a git-cvs server on a linux machine.
Other workarounds would be to nfs or samba mount the code from a linux machine, and commit on linux.
As for telnetd, a bit of googling shows telnetd server for MiamiDX - I have no idea about roadshow.
Sounds like a pretty out there plan you have going
- Admin sponsor
I just want to write code on visual studio code and deploy and run it on a real amiga via a script.
Build, Deploy, Test.... really simple with anything except an Amiga.
WinUAE doesnt cut it when hardware dev is involved too.
So cross-compiling locally and then just sending the binary over the network isn't what you're after?
- Admin sponsor
how do i run the code and see the output without a cli? No i need the remote CLI.dalek wrote: Sat Dec 07, 2019 11:47 pm So cross-compiling locally and then just sending the binary over the network isn't what you're after?
Well i dont understand why its so hard. I just wanna start newshell on a telnetd and git pull my code. Its exceptionally basic computing.
CLI part should be easy enough with telnetd from aminet as a "server" in roadshow - I downloaded the demo version and the config seems straightforward - assuming the same for ftpd.
From there it's just a matter of git post-commit hooks to trigger an expect script that "logs in" to the amiga to do whatever you can imagine.
- Admin sponsor
OK this is the bit i dont get with roadshow. It doesnt create a AmiTCP: assign so i have no idea where to add the inetd lines and i cant find any mention of it easily in the docs.
Aaargh I see what you mean! I gave up with (the demo version of) roadshow. I got this far:
In DEVS:Internet/servers:
telnet stream DH0:serv/telnetd
In DEVS:Internet/users:
NAME=root UID=0 GID=0 PASSWORD=root DIR="S:" SHELL="*newshell * from s:remote-startup"
Took me a while to work out things aren't configured in AmiTCP:db/passwd after all, and that the password in "users" is in plain text.
But it just hangs after successful login (SHIFT+ALT+F8 brings up the network log).
Maybe it works in the registered version? Failing that back to amitcp...
EDIT: this is with telnetd2.0
Actually just tried ttyhandler and it works with the roadshow demo.
Same DEVS:internet/users file.
In DEVS:internet/users:
NAME=root UID=1 GID=1 PASSWORD=root
In DEVS:internet/servers:
telnet stream AmiTCP:serv/ttyhandler
Haven't tried compiling anything though.
Login: root
Password:
TTY0
New Shell process 7
Directory: "Workbench:" Read/Write
C | Classes | Devs |
Expansion | Fonts | L |
Libs | Locale | MUI |
Prefs | Rexxc | S |
Storage | System | Tools |
Trashcan | Utilities | WBStartup |
.backdrop 14 | Devs.info 628 | Disk.info 652 |
Expansion.info 632 | MUI.info 1233 | Prefs.info 724 |
Storage.info 628 | System.info 628 | Tools.info 628 |
Trashcan.info 1172 | Utilities.info 628 | WBStartup.info 628 |
Files: 12 Dirs: 18 Size: 8195
Disk Size: 52427776 Disk Used: 17451520 Disk Free: 34976256
7>
