will it compute? btl's attempt to build the H4
Re: will it compute? btl's attempt to build the H4
Nice build :)
btl
Post by btl »
Hello,
i'm ordering the parts my local electronics store didn't have.
I have questions:
What frequency should QC1 and Q1 be?
Is the DS1315 mandatory?
Do your Serial+Parallel ports line up with the back edge of the mainboard? Mine are 2mm longer than the board.
It would be great if someone remembers where that info is, i'm still reading but can't find.
Greets,
btl
btl wrote: Tue Dec 03, 2019 4:42 pm What frequency should QC1 and Q1 be?
See the bottom of the post BOM.
https://www.exxosforum.co.uk/forum/viewt ... 167#p26532
btl wrote: Tue Dec 03, 2019 4:42 pm Is the DS1315 mandatory?
Nope, just jumper the 2 pins marked on the MB if not using it. You also won't need the battery hold either.
btl wrote: Tue Dec 03, 2019 4:42 pm Do your Serial+Parallel ports line up with the back edge of the mainboard? Mine are 2mm longer than the board.
@Icky Said there was no alignment issues.. I guess its possible different manufacturers may have some variations on stuff.
btl wrote: Tue Dec 03, 2019 4:42 pm It would be great if someone remembers where that info is, i'm still reading but can't find.
What info exactly ? Icky did a page you should look at https://www.exxosforum.co.uk/forum/viewt ... =73&t=2229
btl
Post by btl »
Those Infos you just gave me, thanks! Of course i read the Build Guide, and also the known issues & fixes.
btl
Post by btl »
w00t,
Parts from mouser arrived, i can continue! SMD stuff first...
btl wrote: Fri Dec 06, 2019 3:19 pm Parts from mouser arrived, i can continue! SMD stuff first...
:cheer:
PaulJ
Post by PaulJ »
@btl , lets see some pictures of your efforts. :) :) :)
btl
Post by btl »
Here is what my board looks now
hi-res pic on google photos
SMD stuff is finished, i still need to get some connectors (Power) and some more jumpers.
I found out i got some resistors in wrong physical size.
PaulJ
Post by PaulJ »
:goodpost: Looks like your well on your way. :D
