PhilC's H4 Mongrel edition build x 3
PaulJ
Re: PhilC's H4 Mongrel edition build x 3
Phil, I was just going to point out your perpendicular reset chip but I see Dog beat me to it. Hey maybe the op amp gives you a 90 degree virtual rotation. :) :) :)
You never know Paul, it might. It didnt give me any magic black smoke yet.PaulJ wrote: 29 Nov 2019 22:50 Phil, I was just going to point out your perpendicular reset chip but I see Dog beat me to it. Hey maybe the op amp gives you a 90 degree virtual rotation. :) :) :)
@exxos and @PhilC you have taken me down with my own emoji :)
Nice to see the addition of the :clown:
PaulJ
Phil, speaking of the wrong way around you should take a gander at cr16... believe you may have put it in backwards.
Thanks Paul, I'd got a lot backwards but haven't checked cr16 yet.
Actually just looked, you are right. I really do need to get my eyes tested. :oops:
Working steadily away on my H4s when time allows.
It turns out I dont quite have enough parts to do all 3 but should easily get 2 done.
My second one is going to use SMT glue, mmu and a simm socket.
Top tip for everyone building their boards, it's almost essential you solder in the rs232 socket and cart port. I'd also recommend that you obtain a copy of Diagrom as this may kickstart your machine into life before the diag cart will.
PaulJ
@PhilC you're the master of component alchemy... :pullhair: Is there a chip that I can insert backwards or maybe perpendicular to that socket that will mimic a SN74LS07? Hopefully you will have something for me. :mrgreen:
@PaulJ believe me, I was looking for one myself. Might be worth you chrvkomg the datasheet, as there are a number of ships in this series.
Plugging it in sideways does sound like an interesting solution though.
