TF1260 appears on my doormat
- Admin sponsor
Re: TF1260 appears on my doormat
Issue with the Edu card is that he put the components on the wrong side. They face down which means the heat doesnt dissipate.
I think he also used the middle layers for data which is a complete no no. I could be wrong there though. If its true it explains why it never worked. You need those planes to be "uncut" by other tracks to get the EMC you need.
Anyhow.... It never worked.
go0se
I had wondered why the components on some 1200 cards such as the Blizzard1230 are on the opposite side to those on the 1200 mainboard. I'd assumed it was to allow the SIMMs that they use to remain accessible just by opening the trapdoor rather than having to fully remove the card to swap memory?terriblefire wrote: 28 Nov 2019 08:26 Issue with the Edu card is that he put the components on the wrong side. They face down which means the heat doesnt dissipate.
It does seem like a compromise to have the heat generated from the inverted CPU flowing over the rest of the board before it can dissipate into the case.
- Admin sponsor
Nah.. its 20 times harder to route the board with the components on the same side as the A1200 mainboard. I think thats why its been done that way.go0se wrote: 28 Nov 2019 09:37 I had wondered why the components on some 1200 cards such as the Blizzard1230 are on the opposite side to those on the 1200 mainboard. I'd assumed it was to allow the SIMMs that they use to remain accessible just by opening the trapdoor rather than having to fully remove the card to swap memory?
I asked @ChuckyGang which side to go with before starting and the top was 100% the answer he gave me.
EDIT: I spent most of the route grumbling to myself about the side choice.
- Admin sponsor
Ok so I should probably just say I have built the board and it works although it has some reset issues.
Nothing you aren't capable of sorting out, of that I am sure.terriblefire wrote: 06 Dec 2019 12:10 Ok so I should probably just say I have built the board and it works although it has some reset issues.
Any chance of a photo of the board assembled?
supaduper
I don`t think Steve will mind sharing a couple of pics as I building one with him too,just waiting on a component.
Thanks for sharing. Looks like a reasonably easy board to assemble too.
chucky
DAMN YOU POSTNORD!. DAMN YOU!
- Admin sponsor
just thought it would be fun to reply to this topic on an A1200 running a TF1260. :)
alenppc
- Moderator Team
Does that mean you got the PCMCIA working then?terriblefire wrote: 06 Dec 2019 19:11 just thought it would be fun to reply to this topic on an A1200 running a TF1260. :)
