TF1260 appears on my doormat
Re: TF1260 appears on my doormat
Issue with the Edu card is that he put the components on the wrong side. They face down which means the heat doesnt dissipate.
I think he also used the middle layers for data which is a complete no no. I could be wrong there though. If its true it explains why it never worked. You need those planes to be "uncut" by other tracks to get the EMC you need.
Anyhow.... It never worked.
go0se
Post by go0se »
terriblefire wrote: 28 Nov 2019 08:26 Issue with the Edu card is that he put the components on the wrong side. They face down which means the heat doesnt dissipate.
I had wondered why the components on some 1200 cards such as the Blizzard1230 are on the opposite side to those on the 1200 mainboard. I'd assumed it was to allow the SIMMs that they use to remain accessible just by opening the trapdoor rather than having to fully remove the card to swap memory?
It does seem like a compromise to have the heat generated from the inverted CPU flowing over the rest of the board before it can dissipate into the case.
go0se wrote: 28 Nov 2019 09:37 I had wondered why the components on some 1200 cards such as the Blizzard1230 are on the opposite side to those on the 1200 mainboard. I'd assumed it was to allow the SIMMs that they use to remain accessible just by opening the trapdoor rather than having to fully remove the card to swap memory?
Nah.. its 20 times harder to route the board with the components on the same side as the A1200 mainboard. I think thats why its been done that way.
I asked @ChuckyGang which side to go with before starting and the top was 100% the answer he gave me.
EDIT: I spent most of the route grumbling to myself about the side choice.
Ok so I should probably just say I have built the board and it works although it has some reset issues.
terriblefire wrote: 06 Dec 2019 12:10 Ok so I should probably just say I have built the board and it works although it has some reset issues.
Nothing you aren't capable of sorting out, of that I am sure.
Any chance of a photo of the board assembled?
supaduper
Post by supaduper »
I don`t think Steve will mind sharing a couple of pics as I building one with him too,just waiting on a component.
Thanks for sharing. Looks like a reasonably easy board to assemble too.
chucky
Post by chucky »
DAMN YOU POSTNORD!. DAMN YOU!
just thought it would be fun to reply to this topic on an A1200 running a TF1260. :)
alenppc
Moderator Team
Moderator Team
Post by alenppc »
terriblefire wrote: 06 Dec 2019 19:11 just thought it would be fun to reply to this topic on an A1200 running a TF1260. :)
Does that mean you got the PCMCIA working then?
Users browsing this forum: Amazon [bot], ClaudeBot and 2 guests
