H4D SILK SCREEN LAYER
Current high-res of the silk screen layer. Should help people "find" bits on the board easier.
(zipped high-res)
ssh4d.zip
(168.38 KiB) Downloaded 201 times
PaulJ
Re: H4D SILK SCREEN LAYER
Post by PaulJ »
exxos wrote: Fri Oct 25, 2019 6:17 pm Current high-res of the silk screen layer. Should help people "find" bits on the board easier.
Hi Exxos, been making up a mouser order for parts I'm missing and some extra's. Couple of questions.
1. c5,c6,c7 seem pretty weird to me. c5 and c6 are both labelled on the layout image.
What type of caps are these, why is there 6 locations for three caps, what does the + mean in the symbol center mean, and last but not least is the symbol by the ACIA's c9.
Thanks.. Paul
PaulJ
Post by PaulJ »
Hmm after further examination it looks like surface mount caps. If so what is the package type?
PaulJ wrote: Mon Oct 28, 2019 3:33 pm Hmm after further examination it looks like surface mount caps. If so what is the package type?
The mouser part number is in the BOM..
https://www.exxosforum.co.uk/forum/viewt ... 167#p26532
You can also see them in Icky's build guide which he started the other day...
https://www.exxosforum.co.uk/forum/viewt ... =73&t=2229
exxos wrote: Mon Oct 28, 2019 4:11 pm
I am going to update the build guide later tonight with the other SMT circuit areas so will point out the caps as well.
PaulJ
Post by PaulJ »
Icky wrote: Mon Oct 28, 2019 4:39 pm
Guess I'm just a dumb ass but ordering this SMT stuff is quite a pain. Thought a 1206 was a 1206 ff just like a 1/4 watt resister is a 1/4 resister no matter where you order it but now I run into this. Also the BOM doesn't contain much that cross references here in a USA Mouser web site.???? So I'm basically picking out parts based on what they are but with the SMT its a more difficult be cause I haven't ordered that much of it. So is a 1206 a 1206 or are us and eu parts different?
Does not mouser part numbers not work on the USA site then ?! I don't get why your searching for stuff when I list the codes anyway...
667-ERJ-8ENF75R0V
I get the same page up with mouser.co.uk or mouser.com (USA)
PaulJ
Post by PaulJ »
I don't see those numbers on the BOM I downloaded awhile back. For me the only useful data is 100uf. Then looking at the board image to determine its SMT part. Like I pointed out earlier I guess I'm just challenged. :( :( :( :D
PaulJ wrote: Mon Oct 28, 2019 5:46 pm I don't see those numbers on the BOM I downloaded awhile back. For me the only useful data is 100uf. Then looking at the board image to determine its SMT part. Like I pointed out earlier I guess I'm just challenged. :( :( :( :D
You seem to be missing a column...
derkom
Post by derkom »
Maybe you didn't look far enough to the right? They're in column F. :)
