330 disable function bug
68030 + SDRAM + IDE
alenppc
Moderator Team
Moderator Team
Re: 330 disable function bug
Post by alenppc »
Hmm this is weird. My CD ROM won't work with or without the card now... on both of my consoles.
The disbale function works correctly, but no idea what's up with the CD.
alenppc
Moderator Team
Moderator Team
Post by alenppc »
I got the CD ROM to work again, and now I can confirm it fails to work in 020 mode only.
OK i need to spend time on this but the 360 is on the rig at the moment.. Maybe i need another rig.
wairnair
Post by wairnair »
hi Stephen,
when do you think you could look into this? possibly together with the nvram issue? waiting for a complete TF330..
thank you
I’m not planning to do any 330 work until August due to holidays etc
MickGyver
Post by MickGyver »
I updated the firmware to the version I got from Mark two days ago. He said this issue has been fixed in that firmware, but I still have the same problem (CD32 will not boot when the TF330 is disabled).
The issue with the nvram is fixed.
The disable issue is still present. I’ll fix this eventually.
I suspect I’ll figure it out while working on the TF360
MickGyver
Post by MickGyver »
terriblefire wrote: 19 Sep 2019 15:31 The issue with the nvram is fixed.
Thanks, looking forward to the fix! :)
wairnair
Post by wairnair »
MickGyver wrote: 19 Sep 2019 17:50
same here! :)
Smaug
Post by Smaug »
...and same here also!... 😀
Return to “TF330”
