Hmm this is weird. My CD ROM won't work with or without the card now... on both of my consoles.
The disbale function works correctly, but no idea what's up with the CD.
330 disable function bug
alenppc
- Moderator Team
Re: 330 disable function bug
I got the CD ROM to work again, and now I can confirm it fails to work in 020 mode only.
- Admin sponsor
OK i need to spend time on this but the 360 is on the rig at the moment.. Maybe i need another rig.
wairnair
hi Stephen,
when do you think you could look into this? possibly together with the nvram issue? waiting for a complete TF330..
thank you
thank you
- Admin sponsor
I’m not planning to do any 330 work until August due to holidays etc
MickGyver
I updated the firmware to the version I got from Mark two days ago. He said this issue has been fixed in that firmware, but I still have the same problem (CD32 will not boot when the TF330 is disabled).
- Admin sponsor
The issue with the nvram is fixed.
The disable issue is still present. I’ll fix this eventually.
I suspect I’ll figure it out while working on the TF360
MickGyver
Thanks, looking forward to the fix! :)terriblefire wrote: 19 Sep 2019 15:31 The issue with the nvram is fixed.
wairnair
same here! :)MickGyver wrote: 19 Sep 2019 17:50Thanks, looking forward to the fix! :)terriblefire wrote: 19 Sep 2019 15:31 The issue with the nvram is fixed.
Smaug
...and same here also!... 😀
