Arek's TF534 build
TF534 - 68030 + More RAM Board (More compatible with amiga hardware)
8 Bit Dreams
Moderator Team
Moderator Team
Re: Arek's TF534 build
Post by 8 Bit Dreams »
4-layer lis a bit different to 2-layer boards, middle layers do obsorb much heat
As said - use preheater to avoid lifting pads,
If you do it right you don't need high temperatures, board is heated from bottom and removing such komponents like cpld is a pice of cake...
arkadiusz.makarenko
Moderator Team
Moderator Team
Post by arkadiusz.makarenko »
8 Bit Dreams wrote: 13 Sep 2019 17:33 4-layer lis a bit different to 2-layer boards, middle layers do obsorb much heat
If you do it right you don't need high temperatures, board is heated from bottom and removing sych komponents like cpld is a pice of cake...
Preheater is on my list things to buy. :)
~ Stanislaw Lem
Maximilian
Post by Maximilian »
8 Bit Dreams wrote: 13 Sep 2019 17:33 use preheater to avoid lifting pads
What kind of preheater are you using?
8 Bit Dreams
Moderator Team
Moderator Team
arkadiusz.makarenko
Moderator Team
Moderator Team
I started working on board nr 2.
Should I install R2 ? I did find a note on schematics note about some resistor, and now I am confused a little.
~ Stanislaw Lem
8 Bit Dreams
Moderator Team
Moderator Team
All resistors and caps should be installed
Maximilian wrote: 14 Sep 2019 02:57
My soldering iron is decent enough. I do need to put the temp up to to the ground pins i guess.
arkadiusz.makarenko
Moderator Team
Moderator Team
I completed build of second board, and I get EXACTLY the same output garbadge on serial output. This makes me think that I mostl likekly have bad CPU.
I have not installed RAM yet, but this shoudn't matter ? I still should see clear Diagrom output.
~ Stanislaw Lem
LADmachining
Post by LADmachining »
Have you checked that your serial link is working correctly using a standard board (e.g A500 with 68000) fitted with DiagROM?
arkadiusz.makarenko
Moderator Team
Moderator Team
Yup. Works all right on orginal CPU.
~ Stanislaw Lem
Return to “TF534 (OBSOLETE)”
