Arek's TF534 build
- arkadiusz.makarenko
- Moderator Team
Arek's TF534 build
My first build. It took me 6h.
Tomorrow I am planning to program it, and hopefully start Diagrom.
Forgot to other 0.1 uF caps.
There is no way that someone could build it without microscope and half decent flux.
~ Stanislaw Lem
~ Stanislaw Lem
- 8 Bit Dreams
- Moderator Team
Re: Arek's TF534 build
Hi,
CPU with that mask will probably not work @50Mhz, it will run stable @40Mhz though
- Moderator Team
I have installed 40Mhz crystal here.
Thank you for PCB by the way.
~ Stanislaw Lem
~ Stanislaw Lem
- 8 Bit Dreams
- Moderator Team
You are welcome! glad it arrived safely, was worried it will be lost without tracking..
40Mhz should work nice. Please remember Systest will crap out once MMULib is installed, so scan ram with Systest started from ADF or on a system without MMULibs
- Moderator Team
It may be proper failure
voltage regulator died (or I killed it) and I can't find cplds on jtag chain ... using raspberry pi
~ Stanislaw Lem
~ Stanislaw Lem
- 8 Bit Dreams
- Moderator Team
- Moderator Team
I think I killed one of the chips during soldering. Question is which one.
~ Stanislaw Lem
~ Stanislaw Lem
First thing I would check is a short to ground on the 5V rail, check for continuity across the PWR pins.
Naah, those cplds die hard:)arkadiusz.makarenko wrote: Sat Sep 07, 2019 3:51 pm I think I killed one of the chips during soldering. Question is which one.
- Moderator Team
I get OL one way and something around 120ohm when measured other way round.PaulJ_2.0 wrote: Sat Sep 07, 2019 7:11 pm First thing I would check is a short to ground on the 5V rail, check for continuity across the PWR pins.
found first issue - I had crystal installed upside down. :/
~ Stanislaw Lem
~ Stanislaw Lem
