Fixing up my MEGA STE
Bikerbob
Re: Fixing up my MEGA STE
Post by Bikerbob »
Maeke wrote: 16 Nov 2017 22:16
Bikerbob wrote: 16 Nov 2017 21:35 Thanks for the reply Icky, so the gal is like this? https://www.ebay.ca/itm/5PCS-IC-GAL16V8 ... Sw6EhUN1OR
what did you do? the 68881 or 2? they say the 8882 is improved? I am not going to be doing specific scientific work ;) so .. just looking for improved performance.
James
You can find preprogrammed gal on ebay, or complete kits. Can't give you a link sorry since i'll have only french links.
I would take a french link, I cant find any.. but its ok, I do my own programming.
James
Maeke
Post by Maeke »
Bikerbob wrote: 26 Nov 2017 03:48
Maeke wrote: 16 Nov 2017 22:16 You can find preprogrammed gal on ebay, or complete kits. Can't give you a link sorry since i'll have only french links.
James
Well i didn't post one because all the links were expired.
If i take too long to reply, sorry my cat is sleeping on my laps.
Bikerbob
Post by Bikerbob »
Ok, continuing on with my Mega STEs
Both have new batteries for the RTC.. Does the mega STE still have a Y2K issue? Do you use a little program? aka the one that will only be good to 2019? then what do we do?
I have a Cosmos - it gets time from an npt server and changes the date.. IS that bypassing the Y2K? If I set it and the battery is good.. does it stay?
moving on..
Everything else in the machine seems to be ok, I now have TOS on one machine upgraded to 2.06 US - this will stay, the other is getting a 4mb tos chip and I am installing a 4 way tos into that one.
Floppy - not been having luck with the 1.44 - both machines have the GAL with the -02 the -02-02 controller or Ajax (1 of ea) and both have the 7th dip switch up.. (Both came to me this way) The SMD-340 I got is a bad read most of the time, the one I bought was DOA.. I have a couple of Sony MFP920 drives, I have done the SEL0 mod on one.. it works, but only as a DD drive.. I thought with everything above it was just supposed to work in the mega ste.
Anyone?
Maeke
Post by Maeke »
Bikerbob wrote: 07 Dec 2017 01:27 Ok, continuing on with my Mega STEs
moving on..
Anyone?
check the list in the end of this link http://www.exxosforum.co.uk/atari/last/d ... d/main.htm
Bikerbob
Post by Bikerbob »
Mine is not on the list. It is a T/B63 BH955 chip.. dated 2009.
James
Bikerbob wrote: 07 Dec 2017 20:00 Mine is not on the list. It is a T/B63 BH955 chip.. dated 2009.
Its listed here..
https://www.exxosforum.co.uk/forum/viewt ... ?f=12&t=49
I will update my site to prevent future confusion :)
Bikerbob
Post by Bikerbob »
hmmm I just clicked the link, that was the thread I was refering to .. I just looked its not there, thats why I sent you the PM giving you the dates and the numbers so you could update.
James
Bikerbob
Post by Bikerbob »
OK, I took my time today.. re-did everything.. pulled the PALs and the controllers, cleaned and re-seated.
Checked the link SEL0 SEL1 on the MPF920.. put it back together and I am working on the one machine.. I have not tried the other yet.
SO , good to see, the 920 on the megaste works great, just with the SEL0 jumper done.
Hey Exxos, if I had a 34pin cable with the little twist in it, could I not just use that without doing the SEL0 solder job?
Just asking..
Bikerbob wrote: 09 Dec 2017 02:19 Hey Exxos, if I had a 34pin cable with the little twist in it, could I not just use that without doing the SEL0 solder job?
Try it and let us know :)
Bikerbob
Post by Bikerbob »
Found this on Atari-Forum
Wongck, thanks a lot! I finally got it to work :) but i did'nt solder, i just twisted the cable so pin 10 from the controller went to pin 12 on the fdd and vice versa and it works like a charm :)
So I think if you have a PC cable with the 2 pin twist in it, you can use it.
I am now seeing if I can figure out how to do the media detect thing Alison did on other drives.. not so easy, the sonys I have are all black face.. I have 4 others that are creame, but teac, panasonic alps.. bummer.
James
Users browsing this forum: apple [bot], Baidu [Spider], ClaudeBot, Google [Bot] and 1 guest
