As long as you have the DMA port internally, then you are giving us the choice to use it or not. Let others work out how to implement it as not everyone will want to modify a case to put it under the floppy etc.exxos wrote: 22 Mar 2019 16:17 I've been wondering if its worth adding a internal ultrasatan "option" or not ?, since we have the IDE interface pretty much sorted, it can be used as a plug in module anyway, so I think it renders using ultrasatan a little "pointless" .
The internal DMA port is there, so things can be added, but with space and time always a factor, I am wondering if its really worth the trouble ?
Internal UltraSatan
Re: Internal UltraSatan
Yeah, I am all for mounting the thing being someone else's problem :)Forgottenmyname wrote: 22 Mar 2019 16:38 As long as you have the DMA port internally, then you are giving us the choice to use it or not. Let others work out how to implement it as not everyone will want to modify a case to put it under the floppy etc.
But your 3d printer needs some exercise.exxos wrote: 22 Mar 2019 16:50Yeah, I am all for mounting the thing being someone else's problem :)Forgottenmyname wrote: 22 Mar 2019 16:38 As long as you have the DMA port internally, then you are giving us the choice to use it or not. Let others work out how to implement it as not everyone will want to modify a case to put it under the floppy etc.
P.s. I can soon design something if reqd.
Darklord
I put a regular (external) US in my STacy, but as mentioned, it's a bit involved.
At the time, we didn't have some of Chris's wonderful IDE options. :)
