kludge’s TF534 build
Yes. I’m completely worthless at doing one thing at a time, why?
A kludge is a workaround or quick-and-dirty solution that is clumsy, inelegant, inefficient, difficult to extend and hard to maintain.
My lack of focus:
[ 8 * A500 ][ 2 * A500+ ][ 2 * A600 ][ 2 * A1200 ][ 2 * A2000 w/ A2386 ][ A4000 w/ TF4060, CyberVision 64 3D, FastLane SCSI Z3 ][ CD32 ][ VIC-20 ][ 4 * C64 Breadbin ][ 5 * C64C ][ 2 * C128 ][ C128D ][ C64 DTV ][ 3 * Mac Classics of different types ]
My lack of focus:
Re: kludge’s TF534 build
Crap. Can I use a 10uF cap for C18? Or maybe put a 0.1uF 0603 in? But I don’t know if the pads are close enough together
My lack of focus:
My lack of focus:
Hi Kludge,
I would think you can leave it empty and solder it later.
Just finished my board and start Diagrom testing with RAM, with only a view caps arround the CPU and Regulator no caps on the bottom...
- Attachments
- 20190324_001124.jpg (338.67 KiB) Viewed 9261 times
So... The board boots diagrom now, and reports 4096 kB of fastmem, but as soon as I try to test it it fails.
“Bad block start at $FFFFFFFF and ends at $00000003 with a size of 0kB”
My lack of focus:
My lack of focus:
- 8 Bit Dreams
- Moderator Team
You have to input address space manually!kludge wrote: Sun Mar 24, 2019 8:47 pm So... The board boots diagrom now, and reports 4096 kB of fastmem, but as soon as I try to test it it fails.
Start: 40000000
End: 44000000
I’ll go hide somewhere8 Bit Dreams wrote: Sun Mar 24, 2019 9:01 pmYou have to input address space manually!kludge wrote: Sun Mar 24, 2019 8:47 pm So... The board boots diagrom now, and reports 4096 kB of fastmem, but as soon as I try to test it it fails.
Start: 40000000
End: 44000000
My lack of focus:
My lack of focus:
Hi Kludge ,oke That looks promising!!
Strange thing I noticed today when I test 8MB range like $40000000 -$40800000 it passes the test with me
so it's not reliable
Or maybe its my setup ?
If you can boot from a normal kickstart ,I recommend to use Systest as this seems better for testing the memory ..
It seems to count an awful lot of memory with that range
My lack of focus:
My lack of focus:
Seems ok
Spoiler: This test was done on the A600
My lack of focus:
My lack of focus:
Whoa
you have it running on a A600 !
Your the man !
Could you try testing the range like $40400000-$40800000, just curious if you see the same as me ?
Your the man !
- Attachments
- 8mb-RAM-Diagrom.JPG (58.55 KiB) Viewed 9196 times
