Yes. I’m completely worthless at doing one thing at a time, why?
kludge’s TF534 build
kludge
A kludge is a workaround or quick-and-dirty solution that is clumsy, inelegant, inefficient, difficult to extend and hard to maintain.
My lack of focus:
[ 8 * A500 ][ 2 * A500+ ][ 2 * A600 ][ 2 * A1200 ][ 2 * A2000 w/ A2386 ][ A4000 w/ TF4060, CyberVision 64 3D, FastLane SCSI Z3 ][ CD32 ][ VIC-20 ][ 4 * C64 Breadbin ][ 5 * C64C ][ 2 * C128 ][ C128D ][ C64 DTV ][ 3 * Mac Classics of different types ]
My lack of focus:
kludge
Re: kludge’s TF534 build
Crap. Can I use a 10uF cap for C18? Or maybe put a 0.1uF 0603 in? But I don’t know if the pads are close enough together
My lack of focus:
My lack of focus:
Justme14
Hi Kludge,
I would think you can leave it empty and solder it later.
Just finished my board and start Diagrom testing with RAM, with only a view caps arround the CPU and Regulator no caps on the bottom... :mrgreen:
kludge
So... The board boots diagrom now, and reports 4096 kB of fastmem, but as soon as I try to test it it fails.
“Bad block start at $FFFFFFFF and ends at $00000003 with a size of 0kB”
My lack of focus:
My lack of focus:
8 Bit Dreams
- Moderator Team
You have to input address space manually!kludge wrote: 24 Mar 2019 20:47 So... The board boots diagrom now, and reports 4096 kB of fastmem, but as soon as I try to test it it fails.
Start: 40000000
End: 44000000
kludge
I’ll go hide somewhere :newhere:8 Bit Dreams wrote: 24 Mar 2019 21:01You have to input address space manually!kludge wrote: 24 Mar 2019 20:47 So... The board boots diagrom now, and reports 4096 kB of fastmem, but as soon as I try to test it it fails.
Start: 40000000
End: 44000000
My lack of focus:
My lack of focus:
Justme14
Hi Kludge ,oke That looks promising!!
Strange thing I noticed today when I test 8MB range like $40000000 -$40800000 it passes the test with me :? so it's not reliable :(
Or maybe its my setup ?
If you can boot from a normal kickstart ,I recommend to use Systest as this seems better for testing the memory ..
kludge
It seems to count an awful lot of memory with that range :)
My lack of focus:
My lack of focus:
kludge
Seems ok :)
Spoiler: This test was done on the A600 ;)
My lack of focus:
My lack of focus:
Justme14
Whoa :P :shock: you have it running on a A600 !
Your the man ! :dualthumbup:
Could you try testing the range like $40400000-$40800000, just curious if you see the same as me ?
