TF530 with Fast RAM from another card
TF530 - 63030 + RAM Board
Re: TF530 with Fast RAM from another card
Which actual one? November was the latest release.
The symptoms you have are exactly the same as the ones I had on the kipper2k board before the ram fix.
SukkoPera
Post by SukkoPera »
I *think* I am using 2018_11_4, but I will reflash the board to make sure. The latest firmware seems to be tf530_2018_11_17_beta, shall I try that one?
That last one is aimed at 25mhz users. Not much point.
SukkoPera
Post by SukkoPera »
Just flashed 17_11, same behaviour.
Ok. Dont know then. The data needs to be available for reading on the falling edge between S6 and S7 for my accelerator to pick it up. Just like the kipper2k ram.
SukkoPera
Post by SukkoPera »
Will report that to mkl.
Is this any useful in the meantime?
(Big version here)
Maybe...
A few things are odd about that.
Go to the Memory Editor... Put DEADBEEF into address $600000 and then see if it (a) stays there and (b) if it also appears at $200000... Then reverse the process put it in at $200000 and check $600000
SukkoPera wrote: 15 Feb 2019 22:09 Will report that to mkl.
Did you get anywhere with this? Be useful to know what happened.
SukkoPera
Post by SukkoPera »
Well, mkl made a new firmware right for me, with a new memory decoding method. At first this seemed to pass all tests in diagrom, but then it started failing again. By trial and error I seem to have found a sweet spot on my TF that seems to trigger/fix the errors when pushed down.
It never passes any tests in SysTest though, so I'm not really sure of anything anymore :?.
I need more time for testing, but time never seems to be enough.
Welcome to my world
Return to “TF530”
