TF530 with Fast RAM from another card
SukkoPera
Is there a way (flashing the CPLD, in case) to disable the onboard RAM of the TF530 so that the CPU can be used with Fast RAM from another card?
kludge
Re: TF530 with Fast RAM from another card
I think you should be able to just wipe the RAM CPLD on the TF530 to disable the RAM.
My lack of focus:
[ 8 * A500 ][ 2 * A500+ ][ 2 * A600 ][ 2 * A1200 ][ 2 * A2000 w/ A2386 ][ A4000 w/ TF4060, CyberVision 64 3D, FastLane SCSI Z3 ][ CD32 ][ VIC-20 ][ 4 * C64 Breadbin ][ 5 * C64C ][ 2 * C128 ][ C128D ][ C64 DTV ][ 3 * Mac Classics of different types ]
My lack of focus:
- Admin sponsor
That will kill IDE support.kludge wrote: 13 Feb 2019 15:25 I think you should be able to just wipe the RAM CPLD on the TF530 to disable the RAM.
Sorry no you can’t do this.
EDIT: the latest firmware is compatible with other fastram. Just the autoconfig will clash if the other board is over 4Mb and ZII.
kludge
Ah, crap. In my defense I wrote “I think” ;)
My lack of focus:
My lack of focus:
- Admin sponsor
Would just say it’s rather (not completely but somewhat) pointless to use the TF530 without it’s fastram because the board inserts wait states such that it’s running at 7Mhz effectively. So all you gain is IDE. It’s no longer an accelerator.
SukkoPera
I see your point.
I've tried to get it working with mkl's board, he made a special 4MB-only firmware for me, but I never succeeded. Always black screens.
- Admin sponsor
Start with DiagROM. Does this 4Mb firmware allow for the OS to place the RAM at $600000 ? Because the TF530 grabs the first slot at $200000.SukkoPera wrote: 13 Feb 2019 17:26 I see your point.
Then figure out if you have the latest TF530 firmware.. older firmware wont work with this kind of fastram at all..
Finally it may just not work at all... with or without the onboard fastram.. but I have already spent a year on this making it work and TBH I dont want to work on it anymore.
The Kipper2k RAM does work and i presume those are very similar timings.
SukkoPera
I reported that bit of information to mkl and he came up with a new firmware. I tested it and we have some major improvements! At last the board gets detected!terriblefire wrote: 14 Feb 2019 07:56 Does this 4Mb firmware allow for the OS to place the RAM at $600000 ? Because the TF530 grabs the first slot at $200000.
Although, when I run the memory test, it fails. It fails differently if I run a test of the whole memory...:
... or if I only test the $600000 region:
Other regions test fine. So it seems we're getting closer... Any more hints? ;)
PS: Please ignore my sh*tty video quality.
PS2: Haven't tried diagrom so far, but I can, if that could help.
- Admin sponsor
Diagrom would help.
Which firmware do you have and which TF530 revision/speed
SukkoPera
Latest firmware I'm aware of on a rev.2@50MHz built by Viktor.
Users browsing this forum: CCBot and 65 guests
