STE video synchronisation problem
Re: STE video synchronisation problem
Lift one end of R470 and see if GCLK comes back up ? Also check CCLK both sides of C427.. and R489.
Number_Nine
I've tried removing R470, and after removing - input of R489 (it's R469, I believe though) 4.6V, after R469 - 2.6V, on input of C427 it's 2.6V and on the side connected to pin 17 of 1377 it's same 5V.exxos wrote: 01 Oct 2017 18:31 Lift one end of R470 and see if GCLK comes back up ? Also check CCLK both sides of C427.. and R489.
So just a flat DC voltage there, no signal ?Number_Nine wrote: 01 Oct 2017 19:52 I've tried removing R470, and after removing - input of R489 (it's R469, I believe though) 4.6V, after R469 - 2.6V, on input of C427 it's 2.6V and on the side connected to pin 17 of 1377 it's same 5V.
So to recap, input to R469 has the clock, but the output does not ?
Also with the IC end of R469 lifted, do you still see CCLK on both sides of the resistor ?
This is what I get "left side input" of R469..
3V p-p. Bias 0v.
Output side of R469 (IC side).
about 0.2V p-p (200mV) with 0.4V (400mv ). DC offset.
3V p-p. Bias 0v.
Number_Nine
Yep, no signal, I was blaming that from the beginning, but then I've checked on a good Atari and that was the same flat signal.exxos wrote: 01 Oct 2017 21:36So just a flat DC voltage there, no signal ?Number_Nine wrote: 01 Oct 2017 19:52 I've tried removing R470, and after removing - input of R489 (it's R469, I believe though) 4.6V, after R469 - 2.6V, on input of C427 it's 2.6V and on the side connected to pin 17 of 1377 it's same 5V.
Both input and output of R469 have clock, output has it much weaker (~300mV), though, regardless of the IC side soldered or desoldered.
On schematics R469 is 5.0K, but on the board it's almost 6K, but I don't think that matters as I've tried shorting it out and got no difference.
And what's more interesting - it's all absolutely the same on my second Atari.
I think you need to switch to 100mV on your scope and re-check, as you probably won't see the signal else. See my previous images, if I use 5V/div It would appear flat also on my scope.Number_Nine wrote: 01 Oct 2017 22:00
Number_Nine
Input R469: Output R469: Input C427: Output C427:exxos wrote: 01 Oct 2017 21:53 This is what I get "left side input" of R469..
3V p-p. Bias 0v.
You need to be in x10 mode with your probe, and 100mV/div on scope...
I don't think you will see it with the modes you are using.
Number_Nine
Sorry, I meant flat 5V on 17 pin of 1377 (well, it's also a pulse-ish, but with 5V bias and p-p some very few mV).exxos wrote: 01 Oct 2017 22:07I think you need to switch to 100mV on your scope and re-check, as you probably won't see the signal else. See my previous images, if I use 5V/div It would appear flat also on my scope.Number_Nine wrote: 01 Oct 2017 22:00
Number_Nine
I see it, but it's very unstable and jerky. Is it fairly stable on your machine?exxos wrote: 01 Oct 2017 22:18You need to be in x10 mode with your probe, and 100mV/div on scope...
Users browsing this forum: ClaudeBot, semrush [bot] and 0 guests
