STE video synchronisation problem
Re: STE video synchronisation problem
Lift one end of R470 and see if GCLK comes back up ? Also check CCLK both sides of C427.. and R489.
Number_Nine
Post by Number_Nine »
exxos wrote: Sun Oct 01, 2017 6:31 pm Lift one end of R470 and see if GCLK comes back up ? Also check CCLK both sides of C427.. and R489.
I've tried removing R470, and after removing - input of R489 (it's R469, I believe though) 4.6V, after R469 - 2.6V, on input of C427 it's 2.6V and on the side connected to pin 17 of 1377 it's same 5V.
Number_Nine wrote: Sun Oct 01, 2017 7:52 pm I've tried removing R470, and after removing - input of R489 (it's R469, I believe though) 4.6V, after R469 - 2.6V, on input of C427 it's 2.6V and on the side connected to pin 17 of 1377 it's same 5V.
So just a flat DC voltage there, no signal ?
So to recap, input to R469 has the clock, but the output does not ?
Also with the IC end of R469 lifted, do you still see CCLK on both sides of the resistor ?
This is what I get "left side input" of R469..
3V p-p. Bias 0v.
Output side of R469 (IC side).
about 0.2V p-p (200mV) with 0.4V (400mv ). DC offset.
Number_Nine
exxos wrote: Sun Oct 01, 2017 9:36 pm
Yep, no signal, I was blaming that from the beginning, but then I've checked on a good Atari and that was the same flat signal.
Both input and output of R469 have clock, output has it much weaker (~300mV), though, regardless of the IC side soldered or desoldered.
On schematics R469 is 5.0K, but on the board it's almost 6K, but I don't think that matters as I've tried shorting it out and got no difference.
And what's more interesting - it's all absolutely the same on my second Atari.
Number_Nine wrote: Sun Oct 01, 2017 10:00 pm
I think you need to switch to 100mV on your scope and re-check, as you probably won't see the signal else. See my previous images, if I use 5V/div It would appear flat also on my scope.
Number_Nine
exxos wrote: Sun Oct 01, 2017 9:53 pm This is what I get "left side input" of R469..
3V p-p. Bias 0v.
Input R469:
Output R469:
Input C427:
Output C427:
Number_Nine wrote: Sun Oct 01, 2017 10:09 pm Output C427:
You need to be in x10 mode with your probe, and 100mV/div on scope...
I don't think you will see it with the modes you are using.
Number_Nine
exxos wrote: Sun Oct 01, 2017 10:07 pm
Sorry, I meant flat 5V on 17 pin of 1377 (well, it's also a pulse-ish, but with 5V bias and p-p some very few mV).
Number_Nine
exxos wrote: Sun Oct 01, 2017 10:18 pm
I see it, but it's very unstable and jerky. Is it fairly stable on your machine?
