My Dolphin uses light grey backgrounds. If brightness is too high on the monitor then it shows as white anyway. But looking at the screen all day I really did not like having pure white because it hurts my eyes after a while hence toning it down in my theme in all places. The only problem is with the grey background on the left box is that the icons look a little bit washed out. So I'm not sure if to make that basically off white or not currently..
Had a right old time getting auto detect to work as when I plug in a floppy USB stick or CD-ROM I wanted to update the information automatically as Windows does. That was a whole load of drama by itself but it now seems to be working correctly and automatically.
https://github.com/exxosuk/dolphin-exxos
exxos's linux mint install blog
Re: exxos's linux mint install blog
https://github.com/exxosuk/winamp-mx-linux
(and yes I own the original CDs)
EDIT
OK its got some bugs.. working on it..
Heh. I just use SMPlayer for everything under Linux.
Winamp was a pain to get midi working
Anyway..
https://github.com/exxosuk/wincupl-mx-linux
WinCUPL 5.30.4 installer for Linux.
Theres a more recent version which installs easier.. But one look after it loaded and I thought nope.. Seemes they changed from VB6 to dot net. Food they still support the software but my pet hate is messing with the GUI. So built a installer.
Its gotten more complicated since amd and Intel need different stuff installing it seems.
My theme dolphin installer failed bad on my older laptop. So working though the fixes. Seems Claude "forgot" half the updates so what was pushed to github was broken.
I think past getting MX to be more userfriendly for basic stuff, it's tuning into another unpaid full-time job again. I'd have the same work updating windows if I went down that route again anyway. It's why I just gave up keep updating stuff. By the time I get everything working everything moves on anyway. Everything be perpetually broken and I'd never get anything done.
I may try to get eagle to work in MX. Maybe it work better than in windows. Kinda sucks as it be cool to push a installer for Linux but they abandoned eagle so nowhere to download it from anymore. They probably don't care about hobby use anymore anyway.
My email is another sticking point. What are the chances of Thunderbird being compatible between Linux and windows to share the mailboxes.. Not simple to work though all these problems when I have 20+ years of stuff on my drive.
Anyway..
Been super busy all day on MX again. Mostly trying to work out why the theme didn't work on my laptop, but now fixed ! I also managed to get the title bar transparency working so I now have the basic Windows Aero theme now.
My start menu mimics what I had set in Winstemp with a splash of aero as well
Also getting familiar desktop icons in the mix..which also led me to me thinking about decluttering the desktop this time.
Also added in a Favourites section into dolphin. I was still toying with the idea of having a docker bar above my test bar like I had in Windows. But I thought I would try a slightly different approach and just have one shortcut in the test bar. You go to my favorites listing in Dolphin. The idea is simply to have tabs which would mimic my docker sections and then you just simply drag and drop or right click any file folder or drive or whatever. This way it basically mimics my whole docker system but inside a plane in Dolphin.
