Archie A3000 inbound
Re: Archie A3000 inbound
Post by HigashiJun »
Yes, but only through-hole components...
Finally, found the time to start to take care of my A3000, which in the meantime has started failing again...
First, since I want to avoid buying new parts as much as possible, I started by scavenging those from the failing motherboard:
Next step will be to transplant them on the new A3000 motherboard.
Good luck!
Thanks !
Slowly but surely, the transplantation is beginning to take shape:
And I forgot to tell my Archie will be endowed with 8MB RAM from now on !
8-)
A little progress since yesterday:
Getting closer step by step...
Looking good 😁
At some point it'd be nice to upgrade my A5000 to 8Mb, 4 just isn't enough, but options are limited at the moment.
Thanks !
Yes, 4MB is too low...
The only option is Evilbay, but prices are often pure madness.
HigashiJun wrote: Tue May 05, 2026 1:47 pm Thanks !
Somebody is working on a solution over on Stardot, but how long it'll be I don't know.
Prices on Evilbay and CJE are just eye watering.
rubber_jonnie wrote: Tue May 05, 2026 2:29 pm Somebody is working on a solution over on Stardot, but how long it'll be I don't know.
Depending on which MEMC1a it will use, I guess it won't be cheap either...
And since MEMC1a @ 12MHz seem to be unobtainium now, you will be limited to the more common 10MHz one.
@rubber_jonnie
Oops, spoke too fast...
Here is a chance to get a 12MHz MEMC1a:
https://www.ebay.com/itm/227203114315?_ ... R-7errK_Zw
This guy sells good priced stuff for ACORN computers.
