Acorn Atom Replica build
Re: Acorn Atom Replica build
stephen_usher wrote: 01 Apr 2026 12:28
rubber_jonnie wrote: 01 Apr 2026 12:25 Interesting, I wonder if the green is only from the modulator then? So A bit like the Beeb & Electron that need mods to get colour out of composite. That would make sense.
Sense has nothing to do with it... The Motorola engineers baked it into the chip design.
:dizzy:
So, I have confirmation from over at StarDOT that monochrome over NTSC is indeed correct for the Atom as standard.
I think having seen all the green screen images and used Atomulator, I was assuming green, especially since the Dragon uses the same 6847, and the Dragon uses green aplenty in it's palette :)
I have to say the Atom is running very nicely indeed, quite an interesting build.
I would definitely say it's an interesting and fun build and there are some great upgrades, the Yarrb and AtoMMC in particular are excellent.
@PhilC did you get either of those for your real machine and how did they run if you did?
rubber_jonnie wrote: 01 Apr 2026 15:56 I have to say the Atom is running very nicely indeed, quite an interesting build.
Yes I have a Yaarb, Atommc and a noisekiller for my old Atom. I think that lot cost me more than buying the Atom did :lol:
PhilC wrote: 01 Apr 2026 15:58
I don't have a noisekiller yet but may well build the RGB2HDMI board you sent and I do have a colour board on order.
Yarrb and AtoMMC are just great I have to say.
@rubber_jonnie you'll not need the colour board if you build the rgb2hdmi as it plugs into the same set of header pins
PhilC wrote: 01 Apr 2026 16:27 @rubber_jonnie you'll not need the colour board if you build the rgb2hdmi as it plugs into the same set of header pins
I got it as a back up as the RGB2HDMI board may take a while to build...
Colour board will be faster. and will do until the RGB2HDMI is done.
OK, so the colour board is mostly built:
I'm just waiting on the3 IC's and some caps then I can give it a go. I'll report back when I'm done :)
I may also in the meantime start building the through hole parts of the RGB2HDMI board with the parts I have, but since I'm back to work tomorrow I may have to slow down again.
Nice
A little more done, IC 3 & IC4 fitted:
Annoyingly IC1 and IC3 are the same and I only managed to order one of them... :sigh:
Another one is on the way but I'm waiting for IC2 to come from Ali Express so it could be another week.
Hey ho...
Users browsing this forum: ClaudeBot, gpt [bot], OAI-Search [Bot] and 11 guests
