Acorn Atom Replica build
Re: Acorn Atom Replica build
And for my next trick: Elite
Though I doubt it very playable with the framerate as is...
And Galaxians:
Which runs at a very nice pace.
Post by HigashiJun »
I'm also wondering why your screen is B&W.
HigashiJun wrote: Wed Apr 01, 2026 11:54 am I'm also wondering why your screen is B&W.
It's odd for sure. As I mentioned, the signal at my display is showing as NTSC even on different displays. The crystals are both as specced in the BoM and on the schematic I have.
I'm beginning to wonder if my 6847 is NTSC rather than PAL so I need to check the part number.
I did try an NTSC to PAL converter but it's B&W regardless.
EDIT: It seems the 6847 is NTSC only. So there fore there are additional tricks done to convert the video from NTSC to PAL.
There is apparently a 74LS393 dividing the system clock and generating the extra blank lines to make the frames suitable for 50Hz.
Theres a 74LS74 gating the 6847, a 74LS00/74LS04 combo combining the timing signals and an MC1372 PAL encoder.
I don't remember the MC1372 during the build so I need to go back to the schematic.
rubber_jonnie wrote: Wed Apr 01, 2026 12:00 pm I did try an NTSC to PAL converter but it's B&W regardless.
Correct me if I'm wrong, but isn't this CRTC programmable, so you can set it to PAL or NTSC ?
rubber_jonnie wrote: Wed Apr 01, 2026 12:00 pm I'm beginning to wonder if my 6847 is NTSC rather than PAL so I need to check the part number.
(Sorry, quoted the wrong sentence...)
Yay!
That's odd. I did a post and clicked submit but it obviously never appeared.
My Atom would indicate a grey scale NTSC signal via composite video
For colour you need to fit a colour board or build the rgb2hdmi board I've sent you :D
rubber_jonnie wrote: Wed Apr 01, 2026 12:00 pm EDIT: It seems the 6847 is NTSC only. So there fore there are additional tricks done to convert the video from NTSC to PAL.
Yep. There's a whole section of the Dragon PCB just to try to convert NTSC to PAL (badly)!
I think Acorn decided well to use it as monochrome out as otherwise it'd be all green, like the CoCo/Dragon. Motorola, in their infinite wisdom, never thought that people may want "white" as a colour.
PhilC wrote: Wed Apr 01, 2026 12:21 pm That's odd. I did a post and clicked submit but it obviously never appeared.
Interesting, I wonder if the green is only from the modulator then? So A bit like the Beeb & Electron that need mods to get colour out of composite. That would make sense.
@HigashiJun From what I can tell there is only one flavour of 6847 and it's NTSC.
rubber_jonnie wrote: Wed Apr 01, 2026 12:25 pm Interesting, I wonder if the green is only from the modulator then? So A bit like the Beeb & Electron that need mods to get colour out of composite. That would make sense.
Sense has nothing to do with it... The Motorola engineers baked it into the chip design.
