ST536NG build
Re: ST536NG build
HigashiJun wrote: Fri Dec 05, 2025 1:34 am @exxos
Here's something that might interest you
Oh cool thanks.. Looks like he has a few auctions open as well.. I will try and remember to bid!!
Re: ST536NG build
Post by JezC »
exxos wrote: Fri Dec 05, 2025 10:20 am
I'd be interested in one of those as well...would it be worth buying a couple to reduce overall postage costs maybe?
Re: ST536NG build
Post by HigashiJun »
@exxos @JezC
The seller has another one for sale:
https://www.ebay.com/sch/i.html?item=25 ... n=kjrind01
Re: ST536NG build
HigashiJun wrote: Fri Dec 05, 2025 10:47 am @exxos @JezC
Looks like someone else is very determined, so unfortunately I think I will pass... :(
Re: ST536NG build
exxos wrote: Fri Dec 05, 2025 10:53 am Looks like someone else is very determined, so unfortunately I think I will pass... :(
Yeah, the item is getting pricey...
Re: ST536NG build
Post by JezC »
Yeah, me too!
spen
Re: ST536NG build
Post by spen »
The new xc95288xl board is not booting, not even a flicker of life today.
I've ran the same CPU and same ZIF socket in a working xc95144xl based ST536 for several hours without any issue. I used a storm ST to provide the modified TOS2.06 image.
Swapping out the xc95144xl ST536 for the new xc95288xl board but keeping the same rom image, same storm ST, same MegaST, same CPU, same socket resulted in nothing. The 288 flashed no problem with the beta firmware.
8Mhz clock looking good.
generated E signal at 800Hz, so I think the CPLD is ok, or at least running. how is E derived, just the 68000 clock /10?
All 68000 address lines are quiet, all 68000 data lines are again quiet. Reset drops active for a brief moment.
Getting to the 68030 clock, the oscillator and the bus transceiver underneath whilst it's in the machine and its switched on is going to be fun.
Re: ST536NG build
@spen Have you done the mods and using the latest firmware ? If you just put the latest firmware in without doing the mods,you be shorting out the clocks!
I don't know if external decoders will work either.. IIRC the firmware disables motherboard ROM access.. so your likely introducing a new problem there by not using the intended ROM on the 536..
spen
Re: ST536NG build
Post by spen »
exxos wrote: Mon Dec 08, 2025 12:03 pm @spen Have you done the mods and using the latest firmware ? If you just put the latest firmware in without doing the mods,you be shorting out the clocks!
It's not the STE536 with the funky adapter pins. It's an ST536 2025 edition and fits in a DIP socket. I can see 8Mhz at the CPU CLK pin with reset button held in, and 50Mhz when released. The CLK looks ok???? The 50Mhz clock is a smaller amplitude. I can put a resistor between '030 CLK and GND. I can't do the other mod - the pictures don't correspond to my board and my oscillator is not on a daughter board.
I'll look for a 16bit rom, it'll be vanilla tos2.06 if I can find it. <<<< No change when using onboard rom
Re: ST536NG build
spen wrote: Mon Dec 08, 2025 1:13 pm It's not the STE536 with the funky adapter pins. It's an ST536 2025 edition and fits in a DIP socket.
Makes no odds, you need to do the clock mods and use the onboard ROM.
You won't have a SDRAM clock which will prevent you from booting most likely.
I'm not sure your looking at the right page ?
https://www.exxosforum.co.uk/atari/last/ST536/index.htm
