That's why I requested help in writing a test program which would verify that kinda thing..
But thing is as well.. Nobody noticed the half hour timeout either.. That's a odd thing by itself..
I'll have to take my other falcon apart and try a 14mb card in that to see if a second falcon has the same issues..
Falcon SCSI write issues
Re: Falcon SCSI write issues
Quickly connected up my original Falcon and put the 14 megabyte memory card in and this acts the exact same way
and yes I really need to service this Falcon at some point. :lol: :lol: :roll:
Ooooo guess what I just found..
Same problem. Looks the the ezdrive was stuck on write for a while.. I went for a a shower and came back to a error... This was with HD12.53... 12.71 copied files until it filled up the disk.
So I think that rules out SCSI drive issues.
kohli79
Was the program "ALTRAMFX.PRG" included in the Auto folder in version 12.53?exxos wrote: 23 Sep 2025 21:07 Same problem. Looks the the ezdrive was stuck on write for a while.. I went for a a shower and came back to a error... This was with HD12.53... 12.71 copied files until it filled up the disk.
Life is too short not to have an Amiga/Atari. 8-)
I didn't use it if that's what your asking? I'm not using alt-ram though...kohli79 wrote: 23 Sep 2025 21:19 Was the program "ALTRAMFX.PRG" included in the Auto folder in version 12.53?
kohli79
Okay, sorry. I thought the Falcon was powered by DFB1X ... :oops:
All tests on stock machine :)
Its like DMA doesn't work above 4MB RAM. But the SDMA has all addresses connected..
kohli79
That's very confusing. But a hardware problem can't be completely ruled out?
Its hard to know what to point the finger at :(kohli79 wrote: 23 Sep 2025 22:15 That's very confusing. But a hardware problem can't be completely ruled out?
Hardware faults would be generally more random. Like intermittent bad bits would cause even small files to fail eventually.. But that doesn't seem to be the case.
Its like a limit is reached somewhere. Maybe some odd bus conflict when the videl tries to access ram during a copy :shrug:
But surely more people would have found out about this problem by now if it was a serious hardware fault..:shrug:
I can't do anything really until Jookie gives me a test program. It may give some clues but ultimately it may not be fixable.
Users browsing this forum: ClaudeBot, Google [Bot] and 3 guests
