Wasn't aware of it. I ran it, still no wiser :)
SCSI Driver and firmware test V2.40
½ 2014-2024 Uwe Seimet
SCSI initiator ID is not available
Found SCSI Driver version 1.01
Available buses:
Maximum transfer length: 268435456 ($10000000)
Supported SCSI Driver features:
Arbitration
All SCSI commands
Target control
Maximum transfer length: 130560 ($1FE00)
All SCSI commands
Testing device ID 0 on bus 1 'Atari SCSI'
Arbitration
All SCSI commands
Target control
CheckDev()
Testing with valid bus ID 1
Testing with invalid bus ID 32
Open/Close()
Available handles for bus 1: 30
TEST UNIT READY
INQUIRY
Calling with valid parameters
Raw data: 00:00:02:02:8b:00:00:16:53:45:41:47:41:54:45:20
53:54:33:32:31:35:31:4e:20:20:20:20:20:20:20:20
30:32:38:34:12:00:00:00:24:00:00:00:00:00:00:01
00:00:88:70:00:00:00:03:00:01:3b:d0:00:0f:f4:78
00:10:8e:26:00:10:5a:ca:00:0f:f8:f4:ff:ff:ff:ff
ff:ff:ff:ff:ff:ff:ff:ff:ff:ff:ff:ff:ff:ff:10:00
00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00
00:00:00:00:00:01:00:00:00:00:00:00:00:00:00:00
00:00:00:10:b7:98:00:0f:f4:78:00:10:97:a4:00:10
Device type: Direct Access
Device name: 'SEAGATE ST32151N '
Firmware revision: '0284'
Removable media support: No
Linked command support: No
Relative addressing support: No
Tagged command queuing support: Yes
Synchronous data transfer support: Yes
16-bit wide data transfer support: No
32-bit wide data transfer support: No
RESET condition behavior: Hard RESET
SCSI/SPC version: SCSI-2
Response data format: SCSI-2
Additional length: $8B
Calling with non-existing LUN 7
Testing with requested byte count of 10
REQUEST SENSE
Calling REQUEST SENSE for existing LUN 0
Calling REQUEST SENSE for non-existing LUN 7
Calling REQUEST SENSE again for existing LUN 0
READ CAPACITY
Reading capacity with READ CAPACITY (10)
Maximum block number: 4197404
Block size: 512
Reading capacity with READ CAPACITY (16)
READ CAPACITY (16) is not supported by device
Reading last block (4197404)
Trying to read last block + 1 (4197405)
READ
Reading block 0 with READ (6)
Reading block 0 with READ (10)
Reading block 0 with READ (12)
READ (12) is not supported by device
Reading block 0 with READ (16)
READ (16) is not supported by device
Reading block 0 to odd address with READ (6)
Trying to read block 0 from non-existing LUN 7
SEEK
Seeking block 0 with SEEK (6)
Seeking block 0 with SEEK (10)
MODE SENSE
Reading all mode pages with MODE SENSE (6)
Received 128 data bytes
Available pages list: 1, 2, 3, 4, 7, 8, 10, 0
Page 129: Read-write error recovery page (current, savable)
Raw data: 81:0a:c8:0d:30:00:00:00:0d:00:ff:ff
Page size: 10 bytes
Disable correction (DCR): 0
Disable transfer on error (DTE): 0
Post error (PER): 0
Enable early recovery (EER): 1
Read continuous (RC): 0
Transfer block (TB): 0
Automatic read reallocation (ARRE): 1
Automatic write reallocation (AWRE): 1
Read retry count: 13
Correction span: 48
Head offset count: 0
Data strobe offset count: 0
Write retry count: 13
Recovery time limit: -1 ms
Page 130: Disconnect-reconnect page (current, savable)
Raw data: 82:0e:80:80:00:0a:00:00:00:00:00:00:00:00:00:00
Page size: 14 bytes
Buffer full ratio: 128
Buffer empty ratio: 128
Bus inactivity limit: 10
Disconnect time limit: 0 * 100 us
Connect time limit: 0 * 100 us
Maximum burst size: 0
Data transfer disconnect control (DTDC): 0
Page 131: Format device page (current, savable)
Raw data: 83:16:00:08:00:0a:00:00:00:10:00:7e:02:00:00:01
00:0c:00:01:40:00:00:00
Page size: 22 bytes
Tracks per zone: 8
Alternate sectors per zone: 10
Alternate tracks per zone: 0
Alternate tracks per logical unit: 16
Sectors per track: 126
Data bytes per physical sector: 512
Interleave: 1
Track skew factor: 12
Cylinder skew factor: 1
Soft sector formatting (SSEC): 0
Hard sector formatting (HSEC): 1
Removable (RMB): 0
Surface (SURF): 0
Page 132: Rigid disk drive geometry page (current, savable)
Raw data: 84:16:00:10:51:08:00:00:00:00:00:00:00:00:00:00
00:00:00:00:15:22:00:00
Page size: 22 bytes
Number of cylinders: 4177
Number of heads: 8
Starting cylinder-write precompensation: 0
Starting cylinder-reduced write current: 0
Drive step rate: 0
Landing zone cylinder 0
Rotational offset: 0
Medium rotation rate: 5410
Page 135: Verify error recovery page (current, savable)
Raw data: 87:0a:00:0d:30:00:00:00:00:00:ff:ff
Page size: 10 bytes
Error recovery parameter (DCR): 0
Post error (PER): 0
Enable early recovery (EER): 0
Verify retry count: 13
Verify correction span: 48
Verify recovery time limit: -1 ms
Page 136: Caching page (current, savable)
Raw data: 88:12:11:00:ff:ff:00:00:ff:ff:ff:ff:80:03:00:00
00:00:00:00
Page size: 18 bytes
Read cache disable (RCD): 1
Write cache enable (WCE): 0
Multiplication factor (MF): 0
Write retention priority: 0
Demand read retention priority: 0
Disable pre-fetch transfer length: -1
Minimum pre-fetch: 0
Maxium pre-fetch: -1
Maximum pre-fetch ceiling: -1
Page 138: Control mode page (current, savable)
Raw data: 8a:0a:02:00:00:00:00:00:00:00:00:00
Page size: 10 bytes
Report log exception condition (RLEC): 0
Disable queuing (DQue): 0
Queue error management (QErr): 0
Queue algorithm modifier: 0
Error AEN permission (EAENP): 0
Unit attention AEN permission (UAAENP): 0
Ready AEN permission (RAENP): 0
Enable extended contingent allegiance (EECA): 0
Page 0: Vendor-specific page (current, savable)
Raw data: 80:02:10:00
Reading all mode pages with MODE SENSE (10)
Received 130 data bytes
READ LONG
Reading 0 bytes of sector 0 with READ LONG (10)
Reading 4 bytes of sector 0 with READ LONG (10)
Request has been rejected
Reading 512 bytes of sector 0 with READ LONG (10)
Reading 516 bytes of sector 0 with READ LONG (10)
Reading 0 bytes of sector 0 with READ LONG (16)
READ LONG (16) is not supported by device
READ FORMAT CAPACITIES
READ FORMAT CAPACITIES is not supported by device
GET CONFIGURATION
GET CONFIGURATION is not supported by device
REPORT LUNS
REPORT LUNS is not supported by device
Testing device ID 7 on bus 1 'Atari SCSI'
Arbitration
All SCSI commands
Target control
CheckDev()
Open/Close()
TEST UNIT READY
INQUIRY
Raw data: 03:00:06:02:1f:00:00:00:55:53:45:49:4d:45:54:20
48:44:44:52:49:56:45:52:20:20:20:20:20:20:20:20
31:31:30:31
Device type: Processor
Device name: 'USEIMET HDDRIVER '
Firmware revision: '1101'
Tagged command queuing support: No
Synchronous data transfer support: No
SCSI/SPC version: SPC-4
Additional length: $1F
REQUEST SENSE
Testing SCSI Driver sense buffer handling
MODE SENSE
MODE SENSE (6) is not supported by device
REPORT LUNS
Number of LUNs: 1
LUN list: 0
Testing device ID 0 on bus 2 'Atari IDE'
All SCSI commands
CheckDev()
Testing with valid bus ID 2
Open/Close()
Available handles for bus 2: 30
TEST UNIT READY
INQUIRY
Raw data: 00:80:06:02:1f:00:00:00:53:61:6e:44:69:73:6b:20
53:44:43:46:42:2d:31:30:32:34:20:20:20:20:20:20
48:44:58:20
Device name: 'SanDisk SDCFB-1024 '
Firmware revision: 'HDX '
Removable media support: Yes
REQUEST SENSE
READ CAPACITY
Maximum block number: 2001887
Block size: 512
Maximum block number hi: 0, maximum block number lo: 2001887
Block size: 512
Logical sectors per physical sector: Unknown (1 or more)
Reading last block (2001887)
Trying to read last block + 1 (2001888)
READ
Trying to read IDE block 281474976710656 with READ (16)
SEEK
SEEK (6) is not supported by device
MODE SENSE
READ LONG
READ LONG (10) is not supported by device
GET CONFIGURATION
REPORT LUNS
Number of LUNs: 1
LUN list: 0
