Interests in the CT60e still ?
Are people still interested in obtaining a CT60e ?
I always felt it was a much better install than the original. I have been thinking of trying to revive this great project for some time now. Though only worth the effort if people are still interested in it..
Re: Interests in the CT60e still ?
Post by HigashiJun »
Count me in.
Post by JezC »
I'd be interested...but probably would need to get a suitable CPU (and maybe a second Falcon) as well.
If we could swap between a stock and boosted Falcon without lots of soldering I'd reduce that to just needing the CPU...
:lol: :roll:
JezC wrote: Mon Sep 15, 2025 2:19 pm If we could swap between a stock and boosted Falcon without lots of soldering I'd reduce that to just needing the CPU...
I don't think there is any soldering needed for the CT60e. There's a jumper to enable / disable CT60 mode, that's kinda it anyway IIRC.
don_apple
Post by don_apple »
Does the CT60e allow other cards for the expansion bus (for example the Nova Falcon) to be stacked on top? If yes I might be interested.
According to the picture it looks like on of the pin headers is duplicated on the card, but there doesn't seem to be a duplicated pin hearer for the smaller one.
don_apple wrote: Mon Sep 15, 2025 3:24 pm Does the CT60e allow other cards for the expansion bus (for example the Nova Falcon) to be stacked on top? If yes I might be interested.
AFAIK it doesn't support expansion cards (maybe a bit of a moot point as I don't believe they are made any longer?) . While there is an expansion header, I have no idea what its for.
Maybe someone else knows ?
don_apple
Post by don_apple »
exxos wrote: Mon Sep 15, 2025 3:49 pm (maybe a bit of a moot point as I don't believe they are made any longer?)
Not as moot as you might think: I actually have a Nova Falcon with a Mach32 graphics card, which I currently can't use because the DFB1X doesn't pass through the expansion header.
don_apple wrote: Mon Sep 15, 2025 4:15 pm Not as moot as you might think: I actually have a Nova Falcon with a Mach32 graphics card, which I currently can't use because the DFB1X doesn't pass through the expansion header.
People have got around that problem by soldering a header on top.
Expansion header is for the Super Videl.
Steve wrote: Mon Sep 15, 2025 4:44 pm Expansion header is for the Super Videl.
Thanks.
Return to “CHAT FORUM PUBLIC”
