Good man. Thanks.rubber_jonnie wrote: Mon Aug 18, 2025 5:05 pm So the wires in from the on off switch were not happy, I was cleaning up and some of the pads fell off, perhaps having been overheated previously. I've fixed that and hit it with hot glue for strain relief.
So the SD2IEC device didnt work; Im not sure if its possibly the device itself, or something else. Feel free to remove it. A more 'generic' IEC DIN socket would be much preferred anyway, if thats ok?rubber_jonnie wrote: Mon Aug 18, 2025 5:05 pm Also, for the SD2IEC, how are you supposed to get into that, presently it just goes into the built in stuff.
The other two are literally untouched - removed and carefully posted. You can appreciate what I mean now. Those wires just love to come off.rubber_jonnie wrote: Mon Aug 18, 2025 5:05 pm After a bit of wire fixing, no2 powers up fine, but it has far better visual quality than the modded one. I'll check number 3 later, but it seems to some wires hanging, so a bit more soldering required.
Like I PMd you before; If it were me, I would probably bypass the LED regulation weirdness, but its your call really.rubber_jonnie wrote: Mon Aug 18, 2025 5:05 pm Weirdly it uses the LED to regulate the voltage to the board, though I'm sure it'd be happy to use 3.3v if fed directly.
Its the very least I can do. There are some really cool DTV demos out there and even a game or two.
Of course, I will also pass on anything noteworthy I do with it (once I continue my DTV exploits again).
