Invision ECS faster 32bit uploads
General hardware issues and troubleshooting etc
utri007
Post by utri007 »
Wondering what this means and would it be doable with TF536, from Picasso 96 wiki
Indi in combination with an ACA500+ now supports faster 32bit uploads into the frame buffer memory if hardware ID $0B is found.
This makes it faster with RTG
https://wiki.icomp.de/wiki/P96#Update_V3.6.0
Re: Invision ECS faster 32bit uploads
utri007 wrote: 29 Jul 2025 21:29 Wondering what this means
The ACA500+ is a 68000 accelerator with a 16-bit data bus and the Indivision ECS is a re-implementation of the Denise (with extra bits) which also has a 16-bit data bus. There is no way to perform 32-bit writes from CPU->Indivision. What I suspect it means is they have added a 32-bit write cache internally inside the Indivision ECS CPLD which might improve it's RAM bandwidth (writes to RAM would only be every other cycle). This is pure speculation.
I suspect that this is the hardware ID of the newer Indivision ECS V4 firmware (v1.1).
utri007 wrote: 29 Jul 2025 21:29 would it be doable with TF536, from Picasso 96 wiki
I suspect this is a feature of newer P96 in conjunction with Indivision ECS V4 firmware (v1.1). Accelerator is almost certainly irrelevant.
Return to “AMIGA HARDWARE HELP”
Users browsing this forum: apple [bot], archive.org [bot], ClaudeBot and 9 guests
