My OSI 610 build - Expansion for the OSI 600
Re: My OSI 610 build - Expansion for the OSI 600
*sigh*
That's about the top and bottom of it...
- HigashiJun
rubber_jonnie wrote: Tue Jul 15, 2025 4:47 pm And just to annoy me even further, the FDD interface no longer works, even though the RAM upgrade does...
And we're back up and running
Turns out the FDD side requires PHI2 from the CPU (Pin 39) and there was a bad connection between the CPU and pin 39 of the CPU socket. Now that's remedied I can boot just fine again.
Sometimes it's the simple things that go wrong.
I can get back to looking at FDD's now
- HigashiJun
Thanks
Wow, another ROM just died, that's 5 bad 28C16's now, up and running on another but the other spares I have, UV erasable 27C16's just won't program. I'll have to try them on the other programmer I got from @exxos see if that works.
IIRC I bought them from Ali Express originally, so that probably speaks to their poor reliability. I think the 27C16's were from eBay. If they don't work on my other programmer then they are toast.
What programmer are you using now @rubber_jonnie ? Don't think I ever seen a programmer do the C16 / C32 / C64 chips yet.
I was trying with my TL866 Pro, it's 'supposed' to do them but doesn't. Going to try the MQP170 shortly.exxos wrote: Thu Jul 17, 2025 4:14 pm What programmer are you using now @rubber_jonnie ? Don't think I ever seen a programmer do the C16 / C32 / C64 chips yet.
I've no idea if it supports those. I mean is DOS stuff mostly, so it should be old enough..rubber_jonnie wrote: Thu Jul 17, 2025 4:23 pm I was trying with my TL866 Pro, it's 'supposed' to do them but doesn't. Going to try the MQP170 shortly.
You maybe have to build a adapter and pretend its a larger size and hardwire the extra address lines low.. If the devices have the same number of pins, you could use a 32 as a 16 etc that way..
