Fixing my Milan 040 (or not) blog
peters
Re: Fixing my Milan 040 (or not) blog
Fantastic, welcome to the club, a very exclusive club.
:thanksyellow:
:thumbup:
Yep, and blown a big chip at the same time!Badwolf wrote: 24 Jun 2025 14:52 That screwdriver must have landed on the EEPROM in just the right way to reprogram it with the bootblock at the top and no OS!
I guess screwdriver landed on the ISA card, blew the chip on the MB, then user tried to fix it by burning the flash wrong.
peters
peters
Mine is running boot block 1.04
dml
\o/ \o/ \o/
I was thinking the same when I asked about the accidental mis-flash :p "that's one really advanced screwdriver! where can I get one?"Badwolf wrote: 24 Jun 2025 14:52 That screwdriver must have landed on the EEPROM in just the right way to reprogram it with the bootblock at the top and no OS!
d:m:l
Nice to see it booting. I hope that you can restore full functionality.
If you had a spare 060 (and there is any support for 060 in the Milan ecosystem) then you could possibly use one of the Amiga 040->060 adapter by Mozart & Matze (a1k.org). These are practically passive adapters that translate from 3.3v to 5v
https://eab.abime.net/showthread.php?t=100942
Where is that ? I have 1.02 and it doesn't boot with it.
nevermind, it listed as TEST so I never looked at it.
https://www.schwingen.org/files/milan/tos/
SteveBagley
The change log for v1.01 lists:exxos wrote: 24 Jun 2025 14:59 I get a single beep but no boot up. So not sure whats going on there. Will go back to the previous flash and try again...
So a single beep sounds positive. Looking at the source, the next thing the bootblock does is try and initialise the keyboard, which is on the SuperIO chip so I suspect it might be stuck waiting for that to respond (which is difficult if it is removed :P).V1.01 13.5.2002:
- support Milan V2.1 board: map new config registers, disable watchdog
and RS232/RS485 drivers during startup
- display board revision during startup
- new error beep codes:
1 short beep - normal startup
1 long, 1 short beep: no SIMM in slot 0
1 long, 2 short beeps: wrong type of SIMM in slot 0
1 long, 3 short beeps: bad (defective) SIMM in slot 0
1 long, 4 short beeps: bus error in bootblock during startup
Users browsing this forum: ClaudeBot and 21 guests
