Building a PAK030
bbisi
Building a PAK030
Post by bbisi »
Hello
is here someone online ?
i want to make a pak68 030 . I have all things
Only the patched rom306 and the actual gal files I missed
i am not sure wich I can use.
I can not patch the actual Tos 306. I need a patched version to put it on 4 proms
Someone have an actual list wich gal and also wich files? Where can I get these files
Can anyone help?
Thank you
Bernd
LarryL
Re: Building a PAK030
Post by LarryL »
frank.lukas
Post by frank.lukas »
https://www.markusheiden.de/atari/tospatch.html
Ask @pakman over atari-forum.com for the lasted GAL Files and there are some Hardware Patches needed ...
https://www.atari-forum.com/viewtopic.php?t=37581
bbisi
Post by bbisi »
thank you all
I become , if I use tospatch, th error bios1
what is it
I think I use the right gear tos 3.06
bernd
frank.lukas
German PAK TOS 3.06 ...
TOS 3.06 PAK IDE Patch.zip
Darklord
Post by Darklord »
And just to balance everything out, for anyone who might need it,
here's the latest Pak TOS version that I got from Holger Zimmermann.
For the US, patched to make it boot up into NTSC/60khz, instead of
PAL/50khz. It was driving me crazy on my RGB2HDMI mod and not
being able to figure out why I couldn't get it to boot into NTSC. :)
306USPAK.ZIP
bbisi
PAK030 fehlt 2xMK48S74N-20 2xMK48S80N-20
Post by bbisi »
yes that's what I kneed
I patched the tos306 ger with Markus patches !
thank you
but anyone has these chips for the pak68? Tag Ram 2xMK48S74N-20 or 2xMK48S80N-20
Nothing to become. Only a mainboard with tag rams MK48S74N-20 in Canada? ca 140€
110€ shipping to germany ?????
I have this 2 chips. IDT71B74S20Y But smd type. I use an adapter from smd to wide 28pol. But this is very high and frak2 doesnt fit
Anyone has these chips?
thank you
DoG
Post by DoG »
Tag-ram is pretty hard to find and 20ns for that matter. But I sent you a PM.
frank.lukas
Between PAK and FRAK you can put additional sockets in between to get the right distance ...
bbisi
Post by bbisi »
hallo Frank
Hast du noch solch eine Platine
bestücken würde ich mit meinen IDT71B74S20Y
Oder nur das Platinen Layout
Grüße
Users browsing this forum: ClaudeBot, Perplexity [Bot] and 3 guests
