Building a PAK030
Building a PAK030
Hello
is here someone online ?
i want to make a pak68 030 . I have all things
Only the patched rom306 and the actual gal files I missed
i am not sure wich I can use.
I can not patch the actual Tos 306. I need a patched version to put it on 4 proms
Someone have an actual list wich gal and also wich files? Where can I get these files
Can anyone help?
Thank you
Bernd
Can anyone help?
Thank you
Bernd
- frank.lukas
Re: Building a PAK030
https://www.markusheiden.de/atari/tospatch.html
Ask @pakman over atari-forum.com for the lasted GAL Files and there are some Hardware Patches needed ...
https://www.atari-forum.com/viewtopic.php?t=37581
thank you all
I become , if I use tospatch, th error bios1
what is it
I think I use the right gear tos 3.06
bernd
what is it
bernd
- frank.lukas
German PAK TOS 3.06 ...
And just to balance everything out, for anyone who might need it,
here's the latest Pak TOS version that I got from Holger Zimmermann.
For the US, patched to make it boot up into NTSC/60khz, instead of
PAL/50khz. It was driving me crazy on my RGB2HDMI mod and not
being able to figure out why I couldn't get it to boot into NTSC.
PAK030 fehlt 2xMK48S74N-20 2xMK48S80N-20
yes that's what I kneed
I patched the tos306 ger with Markus patches !
thank you
but anyone has these chips for the pak68? Tag Ram 2xMK48S74N-20 or 2xMK48S80N-20
Nothing to become. Only a mainboard with tag rams MK48S74N-20 in Canada? ca 140€
110€ shipping to germany ?????
I have this 2 chips. IDT71B74S20Y But smd type. I use an adapter from smd to wide 28pol. But this is very high and frak2 doesnt fit
Anyone has these chips?
thank you
thank you
thank you
Tag-ram is pretty hard to find and 20ns for that matter. But I sent you a PM.
- frank.lukas
Between PAK and FRAK you can put additional sockets in between to get the right distance ...
hallo Frank
Hast du noch solch eine Platine
bestücken würde ich mit meinen IDT71B74S20Y
Oder nur das Platinen Layout
Grüße
Grüße
