Understood. These passion projects aren't money makers and they aren't profitable especially when considering the time it takes to develop the hardware (troubleshooting, etc) and software, drivers and whatnot. I can't speak for everyone but I do certainly appreciate the H5 and all the things you and other developers make for us and your patience/willingness to answer my dumb questions.exxos wrote: Mon May 12, 2025 7:10 am Flashyclock and Trudie, I've just never got time to finish them off. They were made during lockdown. But. Never enough hours in the day to do everything... My time went into server attacks, DFB1X, H5 run, STE536, new PSU run, I've got the next batch of DFB1X coming soon.. needs assembly finishing off, CPU,FPUs testing etc plus multiple other little projects like the 206 decoders... It just all ends up pushing H5 add-ons back. Only a few prototypes exist currently. Plus life in general keeps "bullying me".. mix in my day job, RSI... I'm only one person at the end of the day.
I'm hoping to get back to them this year. Problem is, the final design hasn't been tested and I don't know if there are any bugs which need fixing etc yet. The alt-ram driver and clock driver haven't even been done yet. It's likely Trudie will appear first...but also I have no solution for mounting the CF card yet. Likely people will have to figure that out themselves.
@ijor I guess I won the IMP lottery. I got the donor 1040ST that I used to populate this H5 25 years ago given to me for spare parts. It never worked - booted to a white screen with a bunch of weird multi-color bombs. I did try to "diagnose" it with my rudimentary knowledge by putting the socketed chips from the non-working machine one by one into a known working machine and vice versa - but the chips from the non-working machine worked fine and I determined that it was likely a soldered chip or RAM or broken trace on the board. When the H4/5 boards were available I figured I'd try to bring that machine back to life - and luckily did.Interesting. You built an H5 with a full IMP chipset. Be aware, that you might very well be the first. At least I asked some time if anybody tried the IMP chipset on an H4 or H5 board and nobody replied.
Do you have a scope? If you do and you have some time, I would be interested in the 16 MHZ clock signal produced by Shifter. If you can, zoom the horizontal range to just a couple of cycles, enough to be able to estimate the duty cycle. Or if you scope can, include the relevant signal stats.
I don't have a scope and don't know how to use one. If there is a relatively inexpensive scope that is "good" it would probably be a good thing to have provided they're intuitive enough for my dumb ass to figure out how to use it.
Does anyone know if Alan H's MonSTer board (be nice to get the ALT RAM in addition to the flash TOS) or Storm ST would work with the H5?
