:thumbup:Steve wrote: 12 May 2025 20:58 Sorry @exxos it's taken me so long but finally tonight I managed to swap out the Xilinx. Gonna check it for shorts tomorrow and potentially program it.
ST536 STE EDITION
Re: ST536 STE EDITION
Killed my CF card :roll: think I plugged it in one pin to high :roll: PC wont even find it now :roll:
Madness price of some even used ones. Guess I could try some noname china brands and see if they work..
coonsgm
I'm pulling my hair out here reflowing solder points checking for any pin issues. Everything seems good...checked for shorts, checked for non-connected pins going around the PLD about 3 times pin by pin.
I think I'm going to take a break and come back to it in a few days.
You need to use YAARTTT as you should be able to find out if there is a bad bit or not.coonsgm wrote: 12 May 2025 22:56 I'm pulling my hair out here reflowing solder points checking for any pin issues. Everything seems good...checked for shorts, checked for non-connected pins going around the PLD about 3 times pin by pin.
If you have STOS it's easy to do tests there..
loke ($2000000),12345678
print leek($2000000)-
@coonsgm just thought, have you hot the 33pf cap on the CPU ?
viewtopic.php?p=128013&hilit=Bad+clock#p128013
coonsgm
I'll try and take a look tonight!
Is this code doing what I think it's doing ?
address = A[23:11] when shadow_enable = 0
address = shadow_row when shadow_enable =1
EDIT
AND:
address <= shadow_enable ? shadow_row : { A[23:11] };address = shadow_row when shadow_enable =1
EDIT
AND:
wire [12:0] shadow_address = {5'b00111, A[18:11]}; // Maps to 0x4F00000-0x4F7FFFF-
I don't get it :pullhair: :pullhair:
TOSCOPY.PRG is run, it copys TOS206 space to $4F00000 (copy verified in STOS)
Then the PRG accesses 4F80000, which triggers copy_done to go high (also verified)
In main top I had to patch the RAM decode with & (TOSCE | ~copy_done | AS30);
which should make ram_decode =0 on TOSCE =0, copy_done =1, AS30 = 0
ram_decode is 0 on match
As when copy_done is high, and TOSCE = 0 , we are accessing ROM (which is now in TTram)
ram_decode going low also sets the CPU to 50mhz.
then in SDRAM module.
Basically "done"...
BUT it locks up when copy_done goes high, so I assume the address translation isn't working, or the CPU isn't in 50mhz mode during the shadow rom access. Or the idea simply doesn't work, or i've done something dumb.
I have the 16bit ROM disabled when copy_done = 1. The 536 databuffer is turned off. I even ignore STE ROM DTACK. I even stop the STE from seeing ROM access.. I even stop my own ROM DTACK from going going low (as it would likely conflict with the SDRAM logic STERM otherwise).
:shrug: :pullhair: :pullhair: :stars: :stars: :headbang:
:dizzy:
assign TOSCE = ( A[29:20] != 10'hE & A[29:20] != 10'h3FE & A[29:3] != 27'h0 ) | ~RW30 | (AS30 & AS) ;
wire ram_disable = 1'b0; // 1 = disable TTRAM
wire ram_area = ((A[29:28] != 2'b00) | (A[27:24] == 4'b0000)) & (TOSCE | ~copy_done | AS30);
assign ram_decode = ram_disable ? 1'b1 : ram_area;As when copy_done is high, and TOSCE = 0 , we are accessing ROM (which is now in TTram)
// Address translation: Redirect TOS206 addresses to 0x4F00000-0x4F7FFFF
wire shadow_enable = copy_done & ~AS30 & ~TOSCE; // Enable for TOS206 addresses
wire [29:0] A_INT = shadow_enable ? {7'b0011110, A_IN[22:0]} : A_IN; // Translate to 0x4F00000BUT it locks up when copy_done goes high, so I assume the address translation isn't working, or the CPU isn't in 50mhz mode during the shadow rom access. Or the idea simply doesn't work, or i've done something dumb.
:dizzy:
@exxos I should have a bit of spare time over the next few days now I've got the Raven working.
Re the rom copy, can you not do this with the xilinx?
Copying that address range would require a megaload of counters ... It's best to let the CPU do it. But the copying works fine anyway.. it's when it switches from ROM to TTram it locks up.
I am out of ideas...I'll probably have to resort to adding a small SRAM and just bank switch the thing.
Users browsing this forum: apple [bot], ClaudeBot and 3 guests
