Phil C's Raven build
Re: Phil C's Raven build
:crossed1:
So a bit of news, I checked the Mach32 in a PC and it does work, so not sure why it doesn't want to play on the Raven.
Also not sure why the Raven only detects 256K on the Et4000. I'll have a look at the ISA schematic and see if something is amis to cause the blank lines on the ET4000 and the Mach32 to not work.
It could be power related, so I have ordered a Corsair PSU to arrive tomorrow to rule it out.
agranlund
Congrats on nearly there! :)
It kind of looks like it’s missing the lower byte on those 16bit accesses to framebuffer. Which, I suppose could mean any number of things so far.
Would be interesting to see what result you get from pressing the NMI switch and running these two commands from the terminal:
vga init
vga test
(You’re supposed to get a 320x200x8bpp test image)
Interesting about the memory report. My card also report wrong; 512kb instead of 1MB. Perhaps because of the minimal x86 emulation running vgabios.
My card reported wrong on the MS-DOS PC that the ebay seller had too though.
vga init
vga test
@agranlund vga init displays the VGA graphics card details, the same as it would in dos.
vga test then displays an RGB test screen as below:
I've ordered a couple of different graphics cards to try out, including a Trident 8900, another ET4000 and a WDC card. I'd like to learn.how to make these work once my Raven is fully working.
dml
Looks very promising - nice work :)
d:m:l
Thanks. The hardest parts are the small surface mount chips. I'd recommend doing all the surface mount stuff first and would do that way if I was building another Raven.
agranlund
I'm strongly suspecting something related to word access since that worked and the TOS desktop isn't quite.PhilC wrote: 09 May 2025 16:34 vga init displays the VGA graphics card details, the same as it would in dos.
(also, Mach32 relies on that which could explain why that card is not working for you)
I would give this a try to collect further info:
Start with initing the test image:
vga init
vga test
pw $820a4ec0
pb $820a4ec0
pb $820a4ec1
This should produce a blue + green pixel at the beginning of the last red line.
pw $820a4ec0 $ab75
pw $820a4ec0
pb $820a4ec0
pb $820a4ec1
pb $820a4ec0 $ab
pb $820a4ec1 $75
pw $820a4ec0
pb $820a4ec0
pb $820a4ec1
pl $820a4ec0 $12345678
pl $820a4ec0
@agranlund thanks, will give that a go and report back.
Users browsing this forum: ClaudeBot and 37 guests
