Phil C's Raven build
So a lot of the items needed to finish the Raven have arrived today thanks to Mouser. It will leave me with just the ram to obtain, which I'll probably get in a week or so.
Photos of the current status shortly.
Re: Phil C's Raven build
What RAM do you need? I can see if I have some if it isn't weird stuff.PhilC wrote: Thu Sep 05, 2024 10:58 am So a lot of the items needed to finish the Raven have arrived today thanks to Mouser. It will leave me with just the ram to obtain, which I'll probably get in a week or so.
Thanks for the offer @rubber_jonnie they are a bit special and £23 +vat each and I need 6. There's no rush as I still have plenty to do to the motherboard.
I soldered up the majority of the SMT chips and some of the resistors. I get a bit bored doing SMT resistors and caps as they take longer to find than to solder, so will finish that lot off tomorrow, so the board should be complete minus ram.
Oh, interesting, whats special about them?PhilC wrote: Thu Sep 05, 2024 1:47 pm Thanks for the offer @rubber_jonnie they are a bit special and £23 +vat each and I need 6. There's no rush as I still have plenty to do to the motherboard.
@rubber_jonnie I believe they are something like as6c6416-55 chips, two for each 16mb simm.
Definitely weird...PhilC wrote: Thu Sep 05, 2024 2:55 pm @rubber_jonnie I believe they are something like as6c6416-55 chips, two for each 16mb simm.
I got a set of Raven PCBs but now I'm calculating the build cost I doubt I can afford it. If anyone else wants my PCBs let me know.
It's not a cheap build Steve, that's for sure but will be worth it.Steve wrote: Fri Sep 06, 2024 9:03 am I got a set of Raven PCBs but now I'm calculating the build cost I doubt I can afford it. If anyone else wants my PCBs let me know.
Happy to lend you mine once it's up and running? That and I do have one or two spares that could go towards your build which you can have FOC? Will see what I've got and Whatsapp you.
Oki doki, thanks Phil
Nice!PhilC wrote: Thu Sep 05, 2024 1:47 pm I soldered up the majority of the SMT chips and some of the resistors. I get a bit bored doing SMT resistors and caps as they take longer to find than to solder, so will finish that lot off tomorrow, so the board should be complete minus ram.
Not sure which one's worse, those SMD caps/resistors or all the through-hole pins
