Sandord - progress
Re: Sandord - progress
One fix I do is to cut the legs off of a donor chip and solder them on top of the broken ones, giving you legs again.
sandord
Post by sandord »
Forgottenmyname wrote: 28 Oct 2018 20:33 One fix I do is to cut the legs off of a donor chip and solder them on top of the broken ones, giving you legs again.
Nice, I think I'll do this.
sandord
Post by sandord »
To protect the patches that will be on the bottom of the board, I put these spacers on the bottom. I actually have two more spacers mounted to the serial/printer port holes but they're not on the picture.
sandord
Post by sandord »
Alright, I've most finished the shopping list for the remaining parts. I'm just struggling a bit finding the right crystal (I can use the 2.xx one from the ST though, right?) and I don't see where to put the SIP9 caps...
sandord wrote: 29 Oct 2018 23:23 Alright, I've most finished the shopping list for the remaining parts. I'm just struggling a bit finding the right crystal (I can use the 2.xx one from the ST though, right?) and I don't see where to put the SIP9 caps...
Yeah, assume you mean the MFP one ? I am going to stock them in my store at some point..
SIP 9 caps ? There are SIL resistors.. mostly around the CPU area...
have a look at my image... https://www.exxosforum.co.uk/forum/viewt ... =64&t=1268
sandord
Post by sandord »
exxos wrote: 29 Oct 2018 23:29 Yeah, assume you mean the MFP one ? I am going to stock them in my store at some point..
Yeah, the one near the MFP. The one from the shifter shield isn't going on the remake board because it would need an additional circuit, so I have to order an integrated one, right?
exxos wrote: 29 Oct 2018 23:29 SIP 9 caps ? There are SIL resistors.. mostly around the CPU area...
Silly me, I got mislead by the colour and the 105-style coding. I meant the one sitting below the WD1772 but I see that's just a resistor pack.
Yeah you need a 32mhz oscillator 5volt.
sandord
Post by sandord »
Got myself that Weller after all, really glad with it. Heats up from 18 to 370C in 47 seconds. The higher power (50% more) is also very helpful.
sandord wrote: 31 Oct 2018 22:15 Got myself that Weller after all, really glad with it. Heats up from 18 to 370C in 47 seconds. The higher power (50% more) is also very helpful.
Did you get the password protected one :)
sandord
Post by sandord »
Icky wrote: 31 Oct 2018 23:02 Did you get the password protected one :)
:oops:
Return to “ALPHA USER BUILDS”
