Raven060 (kodak80 build)
kodak80
Re: Raven060 (kodak80 build)
Post by kodak80 »
I updated the firmware in my UniJoysticle 2 and thought I would test it on the Raven. The UniJoysticle 2 PCB is my design with just a single 9 pin connector. It did not fit under an Atari ST standard computer so I had almost filed it in the bin but it fits perfectly on the Raven socket. :D
Works as designed. Tyrian works fine with the Xbox controller. Doom, works but have not figured out how to open a door with the Xbox controller.
kodak80
Post by kodak80 »
Just documenting my AUTO folder and order I use with my PicoGUS v2 (with wavetable attached for MIDI).
I have the PicoGUS set to SoundBlaster mode and this is saved:
pgusinit.prg /mode sb /save
Once the above have been run, I do not need PGUINIT.PRG unless I want to change the settings.
Below is the files and order in my AUTO folder and are used for a standard EmuTOS boot only.
AUTOEXEC.PRG
ISA_BIOS.PRG
RVBIOS.PRG
RVNOVA.PRG
SETENV.PRG
MPU401.PRG
MPU401.PRG is needed to have the wavetable MIDI active on my PicoGUS v2. If this is not loaded, I get no MIDI sound output.
I have my ScummST games set to:
Sound driver: SoundBlaster
Music driver: General Midi
luciodra
Post by luciodra »
kodak80 wrote: 01 Apr 2025 08:26 MPU401.PRG is needed to have the wavetable MIDI active on my PicoGUS v2. If this is not loaded, I get no MIDI sound output.
But you have this expansion, right? I don't and to get midi music I have to start Oplmidi...
Raven 060 rev 6 96MHz
ET4000AX 1Mb T0
PicoGUS 2.0
kodak80
Post by kodak80 »
luciodra wrote: 01 Apr 2025 20:59
Correct, OPLMIDI.PRG redirects MIDI to the PicoGUS (SoundBlaster mode) as OPL audio. If I remove MPU401.PRG and add OPLMIDI.PRG in my AUTO folder, the MIDI is sent direct to the PicoGUS and audio is processed through the 3.5mm audio output.
With the OLMIDI.PRG running, Doom, Tyrian and the ScummST games audio all still works, but the audio is a bit tinny compared to having the MIDI played by the wavetable device.
I am also running the latest update for the PicoGUS: https://github.com/polpo/picogus/releases/tag/v2.2.0
luciodra
Post by luciodra »
kodak80 wrote: 02 Apr 2025 08:55 Correct, OPLMIDI.PRG redirects MIDI to the PicoGUS (SoundBlaster mode) as OPL audio. If I remove MPU401.PRG and add OPLMIDI.PRG in my AUTO folder, the MIDI is sent direct to the PicoGUS and audio is processed through the 3.5mm audio output.
With your suggestions I got midi sounds on mxplay and jam. Scumm, gnuboy and Tyrian ok. Unfortunately Doom can hear sfx and midi but after a few minutes it freezes :( . If I launch it without oplmidi I only have sfx but the game is stable.
Does Doom work well with sfx and midi for you ?
Small note, to set Picogus remembering the SB firmware upon reboot I have to give:
pgusinit /mode sb /save
in the same line.
ET4000AX 1Mb T0
PicoGUS 2.0
kodak80
Post by kodak80 »
agranlund wrote: 18 Jun 2025 22:41
kodak80 wrote: 17 Jun 2025 09:25 I jumped the gun and already ordered these PCBs.
I've built mine today and from an initial quick test the hardware appears to work.
Though it looks like there's an important software issues to fix before it's properly usable -- I tried a non-debug build for the first time and notice mouse isn't entirely happy (same behaviour for usb, ps2 and joyport mice which I'm happy about since that strongly indicates a problem in the common mouse code)
I'm sure more stuff will be found when the more uncommon ikbd modes are tested too so don't throw away that Eiffel PIC just yet :)
Unimplemented so far:
- fan control
- cpu temp (requires motherboard patch wire)
- software power-off (requires motherboard patch wire + Raven support in MiNT)
Untested so far:
- joyport mouse right button (requires motherboard patch wire)
You shouldn't need to solder J104 if you don't want to, but it also won't hurt it you do.
Normal operation is having the header completely open (support for external oscillator is not implemented)
First-time programming can be done without jumpering for programming mode, and subsequent programming can be initiated from software. Jumpering for programming mode should only be needed if it for some reason ends up bricked.
Pin0 is 115200 baud serial output for debug builds of the firmware
Also don't forget to remove the pin for the key position if you're using a normal 2x5 pinheader on J103 :)
Chips arrived, CKBD rev.C board built, CH559L chip programmed. Quickly tested in my Raven with PS2 mouse and keyboard and they seem to work fine. :D Will look to test USB over the weekend all being well. :)
agranlund
Post by agranlund »
(most internal usb plugs have that position blocked)
In hindsight, I should have changed the footprint to not have a through-hole there.
agranlund
Post by agranlund »
If you need to change settings you can manipulate them directly from the raven serial monitor:
(Update: I realised you need the latest bootrom to do these things. I'll make a new release package this weekend :) )
reading a value (it prints 4 bytes starting at the index you specify)
kbd get <idx>
setting a value
kbd set <idx> <byte>
commit changes to ckbd flash
kbd save
fuint16_t scaling values are 16 bit fixed point in 8.8 format. The first byte of the setting is the decimal part and the second is the integer.
for example, set Usb mouse scale to 1.0
kbd set $14 0
kbd set $15 1
example, set Usb mouse scale to 1.5
kbd set $14 128
kbd set $15 1
example, setting legacy mouse mode to Amiga
kbd set $22 1
Here's the entire settings structure (the eiffel parts can be manipulated with the EiffelCF program)
typedef struct
/* 0x00 */  uint32_t Magic;
/* 0x04 */  uint32_t Version;
/* 0x08 */  uint32_t Changed;
            uint8_t pad0C[4];
/* 0x10 */  fuint16_t PS2MouseScale;
/* 0x12 */  fuint16_t PS2WheelScale;
/* 0x14 */  fuint16_t UsbMouseScale;
/* 0x16 */  fuint16_t UsbWheelScale;
/* 0x18 */  fuint16_t LegacyMouseScale;
            uint8_t pad1A[6];
/* 0x20 */  uint8_t UsbKeyboardReportMode;          // usb keyboard boot or report mode
/* 0x21 */  uint8_t UsbMouseReportMode;             // usb mouse boot or report mode
/* 0x22 */  uint8_t LegacyMouseAmiga;               // atari or amiga mouse
/* 0x23 */  uint8_t CoreTempShutdown;               // abbbbbbb. a = enable, b = temp (0-127)
/* 0x24 */  uint8_t FanControl0;
/* 0x25 */  uint8_t FanControl1;
            uint8_t pad26[10];
/* 0x30 */  settings_eiffel_mouse_t EiffelMouse;    // eiffel mouse settings
/* 0x38 */  settings_eiffel_temp_t EiffelTemp[2];   // eiffel temperature tables
/* 0x6C */  uint8_t EiffelKeymap[0x90];             // eiffel keyboard usertable
} settings_t;
kodak80
Post by kodak80 »
Additional USB erroneous header pin has been removed and I found a USB motherboard adapter to fit the rear slots and have now successfully tested a Dell USB keyboard and USB Microsoft Basic Mouse.
Both work fine. :)
I guess I will need to get the various firmware updates just released programmed and tested...
https://github.com/agranlund/raven/rele ... .A1.latest
agranlund
Post by agranlund »
kodak80 wrote: 21 Jun 2025 00:50 Dell USB keyboard and USB Microsoft Basic Mouse.
Both work fine. :)
That's awesome! Always very nice to know it worked for someone else too and not just my particular setup :)
Return to “RAVEN 060 - USER BUILDS”
Users browsing this forum: ClaudeBot, LarryL, Mikerochip, redpixel and 18 guests
