ROM now programmed with the last ROM shared.
- Raven060 kodak80 Programmer and ROM 20241110.jpg (373.24 KiB) Viewed 2929 times
Managed to get
Coolterm working on
Windows 11. I made these changes to the settings:
Serial Port section:
Baudrate set to 750000, data bits 8, Parity none, Stop bits 1
Under Terminal section:
Enter Key Emulation set to CR instead of CR+LF
Then connected to COM port.
E erased
I showed the chip information
P to commence programming
Then in the top menu under Connection, select "Send Text/Binary File..."
Select the ROM file and then watch it send with the progress bar. The Pi LED blinks as advised as it processed the file.
When completed transferring, a message shows the transferred size which corresponded with the ROM file size.
- Raven060 kodak80 ROM in SIMM 20241110.jpg (357.25 KiB) Viewed 2929 times
