I'm am a new owner of a TF1260 with a 68060 rev 6 CPU.
The problem I am having is that I am only getting 4MB/s read speeds from the IDE interface on the TF1260. I've seen people getting around 6MB/s.
I am using kickrom 3.2.2 chips with the ehide.device in ROM. I am also using MMULib and MuFastROM to remap the kickrom into Fast RAM.
I've tried a bunch of different CF cards and tested in WB3.1 and AmigaOS 3.2.2.1 but still getting 4MB/s.
Any idea what I might be doing wrong? :?:
TF1260 slow IDE speed
- Admin sponsor
Re: TF1260 slow IDE speed
What firmware? cpuspeed shouldAmigaz wrote: 06 Mar 2025 19:40 I'm am a new owner of a TF1260 with a 68060 rev 6 CPU.
tell you.
4MB/s is indicative of older firmwares
Amigaz
I just bought it from Amigastore.eu and according to the product info it should have the latest firmware https://amigastore.eu/en/873-terrible-f ... b-ide.html
I will double check with the cpu speed tool to see which firmware that is on the card
Amigaz
Is is running the latest firmware.terriblefire wrote: 07 Mar 2025 07:42What firmware? cpuspeed shouldAmigaz wrote: 06 Mar 2025 19:40 I'm am a new owner of a TF1260 with a 68060 rev 6 CPU.
tell you.
Any ideas what else to check?
- Admin sponsor
I don't have any suggestions.
I have one suggestion to rule out an OS configuration problem: Ask someone who is getting 6mb/s to image their CF card for you, then write that image to your card and test it out.
matt020
Try a different CF card adapter.
- Admin sponsor
also do not use sysinfo for benchmarking. it's broken
