Exxos's H5C5B Build
All related information and builds for the 2025 edition.
Re: Exxos's H5C5B Build
So, the sticker will read: "Special Magic Smoke Generator."? :D
jasonfloyd
Post by jasonfloyd »
I'm just amused that the problem is located directly across from the "Probably fixed edition" text :D
jasonfloyd wrote: Fri Feb 28, 2025 10:44 pm I'm just amused that the problem is located directly across from the "Probably fixed edition" text :D
I'm forever the realist :)
jasonfloyd
Received the "Mostly Assembled" board today! I still need to acquire a few parts and realized I also need a PLCC 68000 CPU instead of my DIP one I have.
I'll create a post once I actually get around to building it.
DoG
Post by DoG »
jasonfloyd wrote: Tue Mar 25, 2025 7:20 pm Received the "Mostly Assembled" board today! I still need to acquire a few parts and realized I also need a PLCC 68000 CPU instead of my DIP one I have.
You don't have to use plcc. You can still use dip if you want to. Just shoose one of them and you are good to go.
jasonfloyd
DoG wrote: Tue Mar 25, 2025 8:22 pm
Ahh just populate one of the 5v Bus IO Port slots with a socket and use my existing DIP 68k. Thanks!
Return to “H5 C5B USER BUILDS”
